Rail (625Wh) tubeless pump
idunne
merseyside liverpool
am thinking on buying one of these tubeless booster pumps that seat mtb tires are they worth the money or should i go with the make your own with a fire extinguisher anyone out there got a views on these booster pumps
I got one when I went tubeless I was actually very impressed with it. Solid purchase.
I have a JoeBlow Booster Pump by Topeak.
I highly rate it as both a pump, and a tubeless inflator. Flick a switch to fill the canister, pump to 160psi, and flick the switch back again - and the tyre springs into life. You can then carry on pumping if it's not enough.
I wouldn't be without it anymore!
Airshot tubeless tyre inflator, I wouldn't try fitting a new tyre tubeless without one.
£48.49 + free UK delivery from Tredz
Please tell me you didnt pay that for it?
Yep. Has a lot of features for a digital pump. Actually it’s cheaper than most of the charge pumps out there. Works better than my DEWALT stand up air compressor. Plus it’s portable. Buy once cry once. Did you get the Orbea discount code?
I just use a regular Bontrager floor pump. Only had an issue setting up a tubeless tyre once or twice, but that was due to seriously dented rims. Then I just took it to the nearest gas station and inflated it there (unscrewed the valve)
I bought a 2nd hand electric Air compressor for £40 which is ideal
I use it for my car, van, motorbike and fitting tubless tyres on my ebike
I use the TOPEAK TUBIBOOSTER X TUBELESS TIRE INFLATOR and retired my air compressor as it was taking up too much space. Great purchase for me!
I too have one of those, and a Joe blow better to put air in the tyre than Co2 which can effect your sealant.
Of course if your on the trail I carry a Co2 for convenience but when I get back to me car I put air back in the tyre
