Rail - Dropper post
My Trek Rail 5 2020 XL has the original TranzX JD-YSP18 (130mm travel, internal routing, 425mm length) and it's getting a little out of shape. I could try to fix it with Oneup V1 rebuild kit but at the same time why not upgrade to.
Any idea/experience if the 31,6mm/240mm/610mm could fit XL-frame?
I think it's about if the (INSERT LENGHT = 337mm) will fit.
For those who decide to fit an AXS Reverb 170mm dropper into a medium sized Rail…measure carefully. Seat hight is a critical factor because the dropper bottoms out at the bend of the down-tube.
I was able to slam the post to within 5mm (or less) for the correct seat hight for me (5’9”). Having a longer dropper allowed me to drop the seat much lower for downhill drops and technical runs. IMG_6451.jpeg
My inseam is 32” I think 🤔. This size is not for everyone but this length of dropper works perfectly for my geometry.
I was able to slam the post to within 5mm (or less) for the correct seat hight for me (5’9”). Having a longer dropper allowed me to drop the seat much lower for downhill drops and technical runs. View attachment 118620
Do you know what the insertion length of your 170 reverb is?
Regarding the insertion depth of the seat tube on a 2020 Rail 9.7, using a 170mm AXS Reverb dropper.
Insertion depth was measured at 234mm(when the dropper post touched the frame).
I just installed the OneUp V2 210mm dropper on my Trek Rail 7 Gen 2 ('22) size large. I am able to slam it all the way down.
