MAX. POWER ON Motor Bosch Performance Line CX - Smart System 85 Nm
Maco
Maribor, Slovenia
Hi, eMTB
(Motor Bosch Performance Line CX - Smart System 85 Nm, Battery Bosch PowerTube 750 Wh, Display Bosch Kiox 300)
It is normal for the motor to give a power of 400-550W at a moment. My friend has the same bike, but her motor does not go over 250W (Pictures are attached) ?
I ask this because my motor turns off several times while driving. They replaced the battery, but I'm not sure if that's the solution.
it is normal for the motor to give a power of 400-550W at a moment ?
My friend has the same bike on the same ride, but her motor does not go over 250W (pictures are attached).
I ask this because my engine turns off several times while driving. They replaced the battery, but I'm not sure if that's the solution.
Can someone send me pictures of the Bosch Flow-power ?
Primerjava Gaj 04062023 Maco Majda.png Primerjava Kordek 01062023 Maco Majda.png
Matt van
32
20
Canberra ACT
The watts is related to the speed so 250w is like 25kph cut off speed for the motor. You can go quicker but its just you pedaling . and the nm is how quick it gets there.
yorkshire89
468
661
North Yorkshire
Is this motor power or rider power? I don't have the smart system but my display shows me rider input in Watts.
The Bosch motor can give peak power around 600w for info.
I think your issue is unrelated to what you are seeing and should be going back to Bosch for more diagnostics if not resolved.
20,498
Didn't you just make a post saying that you didn't understand power/torque and so on ??
Your motor shouldn't turn off. I think it can shut off for over heating, but it's unlikely. It's more likely your battery mounting needs adjusting, or there's a cable not connected somewhere correctly or is getting squashed/pulled somewhere.
I've not used the flow app. Are you sure the power numbers being shown are motor power and not rider power ?
Shark58
160
113
The Flow app definitely display rider power. During a ride you should see momentary rider power on the display and after the ride you will see max and average rider power from that ride.
There is no info about motor power available on the display or the app.
The max mechanical power for a Bosch CX Gen4 motor is 680 watts.
Ark
400
333
Newcastle Upon Tyne
The power numbers are based on the riders output measured by the power meter built into the motor.
with the bike powered on but no assistance it probably still shows you a power number output on the display
Here's my last ride as you can see I have some big spikes in there too
Taken from Strava so looks different to flow app. but it's logged direct from the motor
The only times your motor should stop is when you hit whatever the speed restriction is for your country.
for me in the UK it's 15.5mph but I can sit around 16.5mph before it feels like it's stopped.
I think the motors are + or - 10% tolerance on the speed restrictor limit so I guess some motors are "lucky" and some aren't.
it's also a staggered off so you don't really notice it as the power fades out
Uktonyb77
34
24
Uk
The wheel size on the bike and how the dealer configured wheel size in Bosch diagnostics would also reflect when the speed restrictor cuts in. If configured wrongly and in your favor then the motor doesn’t cut till around 16.5 ish mph . That’s from my own experience.
cappuccino34
530
328
Helmshore
FYI, if you adjust the wheel size in the app it affects the speed that the bike thinks it's doing, so the speed when at the limiter on the Bosch display won't change. To see Actual speed you need an external device such as a GPS.
Shark58
160
113
The opposite is correct.
The user/dealer adjustable wheel size only changes the displayed speed. There is a limit of +/- 5% from the original size value.
The motor has a second wheel size programmed which is used for the cut-off limit from the motor. Only a Bosch representative in cooperation with the bike manufacturer can change that value.
cappuccino34
530
328
Helmshore
You're talking about a different variable.
Production variable vs user variable.
There's a limit to the degree of adjustment that the user can make, which is intended for different tyre options that the user might fit.
The production variable is for the fitted wheel size and that isn't user adjustable.
Both values affect the bike's concept of speed, but by potentially differing amounts.
