Anyone snow foam their bike?
Colin1517
50
101
Lancashire
As the title suggests. I wondered about this while washing the car over the weekend. I wouldn’t jet wash it, but snow foam is a maybe.
Do’s, don’ts, thoughts, anyone??
Plummet
Flash Git
Mar 16, 2023
934
1,351
New Zealand
What ever you do, dont get ANY washing liquid (except water, water is ok)on the brakes of rotors.
You risk contamination of the brake pads.
Dave_B
1,420
1,542
Newquay
AutoGlym.
Not very much at all. I actually use less when foaming than when spraying normally.
Bomble
646
380
Yorkshire
I use rhino goo in the snow foam thing which came with my Worx Hydroshot.
Quicker than using the spray bottle and uses less.
Dave_B
1,420
1,542
Newquay
I use this to dry the bike, it’s brilliant.
The EMF
🔱 Aquaman 🔱
1,153
2,000
South East Northumberland
I’ve seen it all now 😆……..
And I thought I was the ultimate bike anorak 😂😂
mustclime
239
148
New Jerzy
Not a fan of using soapy water on a bike. The reason soap helps get thing clean is it brakes down water surface tension allowing the water get in around the “dirt”. The water seals on all bike bearings rely on water surface tension to keep water out. Remove water surface tension and the water is more able slip past the bearing seals.
My advice is use low pressure water and a brush or rag to clean the bike, then use an auto detailing spray on the frame(avoid the brakes). JMO
RustyMTB
2,536
6,206
The key to longevity on all ebikes is keeping water away from the crank spindles. You're not going to get water entering a motor through the case, they're too well sealed. If it's assembled correctly, no water will get in through the connector plugs, which leaves the cranks. All crank spindles cross from inside to outside the motor, they are the weak point. Pay attention to them & you'll be ok.
Bones
754
992
Harrogate
Stupid idea 🤔
Bones
754
992
Harrogate
Mine was just a bottle of fluid with a hose pipe connection. Some cheap car plan stuff from an auto jumble. I don't think it's anywhere near as good as a proper setup.
iamanej
53
23
Slovenija
You really dont jet wash it?
I do it and take care that I am far away at bearings and motor.
Gilbo
92
48
Isle of man
Hi
Snow foamed my bike loads of times over the winter,I use the karcher stuff they sell at B&Q. When bike is really dirty I get the heavy off with hose water pressure snow foam the bike then rinse with pressure washer (from a distance). Comes up like new.
Stoffel
107
183
Cotswolds UK
I also use a dryer, different make to this but same sort of thing.
I’ve had it for years, first bought it to dry the motorbikes and now also use it on our emtbs.
I’m always recommending it to people but they just think I’m nuts and I don’t think the neighbours appreciate the noise of it, I don’t care, it works a treat!
522K
