Levo Gen 2 XX Eagle AXS E-Bike Transmission Groupset
GordS
Brampton Ontario
Is the SRAM XX Eagle AXS E-Bike Groupset GS-XX-EPA-D1 compatible with my 2021 Gen 2 Turbo Levo Comp?
Does it have UDH? If not, then NO. Very simple.
Gen2 doesn't have UDH.
I wouldn't completely rely on SRAM UDH bike list, as the photo under Levo is actually a Levo SL ...
And I can assure you that UDH does not fit on Gen2 Levos: a hole in the chainstay must be 20mm for UHD, on Gen2 Levos this hole is 15,5mm to allow installation of Specialized S172600001 thru axle derailleur hanger aka Sandwich Hanger ...
You can also check a complete UDH specification/documentation which is intended for bike manufacturers here: https://www.universalderailleurhanger.com/downloads/UDH_And_Full_Mount_Rear_Derailleur_Rev_H.zip
And what about Levo Gen 3? It does have UDH, but all webshops explicitly say that the Brose groupset is not compatible with Levo Gen 3?!
For example:
It’s working fine on several Gen 3 installs that I am aware of.
For example:
If you look closely you'll see that non-compatibility reffers to the crankset which will clearly not fit on Levo, but everything else should fit (talking about Gen3 Levo) ... better to choose a group without crank: XX Eagle AXS Transmission E-MTB Group (without crank)
Has SRAM stated which groupset will be the best fitment for the gen 3 Levo yet?
The XO cranks fit nicely no Problem whatsoever! See picture!
    668K
