Marjoriefinnegan
Hi guys.
Set up is new 11 speed linkglide- shifter, chain, block, rear mech.
Problem is this...it will shift from small cog (1)up one, then when you shift from 2 to 3 ( one click) it will go to 4 instead, and maybe do a double shift again later on in the block.
So basically getting two shifts for one click.
Have been spannering bikes for many years and this is a new one on me.
Set it up as per Shimano instructions and have double checked high/low/b also chain length. Also changed the inner and outer cable.
Even tried a 100mm inner outer set up with the shifter next to the mech to eliminate cable issues.
Any thoughts appreciated!
