Shimano Battery Life Poll
The App eTube Project V5, Professional, last Version, shows the number of loads with my three BT-E8010 à 504 Wh.
But how is it with BT-E8016 à 630 Wh ?
Question 1: does somebody know if the PC app eTube Project V5, last version, shows the number of full loads of the BT-E8016?
Question 2: does somebody know if Shimano fixed this issue wth BT-E8016, and how?
It says that: "It has been confirmed that there are cases where the bicycle cannot be started after the BT-E8016 battery has been fully charged. If this occurs, plug the charger into the battery, confirm the LED lights up, then remove the charging plug. This enables the bicycle to be started. Rest assured that this issue has no negative effects on safety. We will inform you as soon as a permanent solution becomes available. "
I do not want to try to purchase for the third time a BT-E8016, if I have to return it back because of this issue after a full load.
Shimano never published since 3 years a confirmation, they fixed it.
I have a BT-E8016 bought one year ago and it has never had this issue. After 10 cycles degradation is 98%, much better than the BT-E8010
Interestingly, after 2928km and 30 cycles, my battery health ticked-over to 94% (NB. at 29 cycles it still showed 96%).
So my average full battery range is ~100km, however…
If I ride in Eco (36% assist) at 20°C my theoretical range is 170km, and I am confident I could do 150km, based on my L2B OR experience
If I ride in Trail (63% assist) at 2°C my range drops to ~50km, based on my observation, as after 41km hard riding in Surrey Hills, I had 20% batt left, and at that rate I would probably do 50km.
In conclusion, the same rider, diff conditions and vastly different effective range. You need to get to know your bike and your style, so that you can use it effectively.
1. 504kwh
2. May2020, April 2023 gone, not turning on, but battery led is flashing still
3. cycles = do not bother, 1000 cycles before battery expires the 2 yr warranty they wont replace it
4. charger E6002
5. motor = e8000
i used a 1 amp load to discharge the battery. surely enough, the shimano folks designed the battery to brick itself when not recognizing a movement of power.
after replacing the SFK-4030A "battery insurance" fuse, the battery internally bricked itself with a code.
[/MEDIA]
How did you apply the 1 amp charge?
I have discharged mine (8010) in the lab, down to 28V with up to 6 amps and had no problem. It´s is still alive
DC load was connected internally in the power pack with the battery off
It's more than two years from the last post but I would like to contribute with some info and actual measurements.
The short version is that the remaining life or capacity of the Shimano batteries is wrong most of the time, as the battery have much less wear than reported. Read the rest for details.
I have an e-bike with an E8000 engine and a BT-E8010 battery. Using the free version of the eTuning Android app, I checked the battery's remaining life and observed that its capacity has been decreasing at an alarming rate. After only 51 cycles, the battery was at 81%. I should mention that most of the time, the battery was only charged to ~80% using a timer. It was also stored at a controlled 18 degrees Celsius with low humidity and was never used below 0 degrees. Although the remaining capacity decreased significantly, I could not feel it during actual usage. This made me wish I could measure the battery's actual capacity, but unfortunately, I don't know how to open its high-voltage output to do so. I know how to do this with a Bosch Powerpack.
A while ago, I bought a used E8010 battery. The eTuning app reported that it had undergone 120 cycles and had 74% of its capacity remaining. Terrible! Since it was a spare battery, I could afford to experiment with it without risking being left without a battery for my e-bike in case something unexpected happened. I searched the internet for information about how to open the battery. My previous experience with Bosch power packs taught me that they are very difficult to open. This is the best video I found:
You need an T15 security bit to open the case. There are only 4 screws that need to be removed. There are no horrible plastic clips like in Bosch powerpack!
As mentioned in the previous YouTube video, the battery contained Sony VC7 18650 3500mAh cells. This document contains many interesting facts, starting with the introduction of the cells in 2016, which are still state of the art today. The few 18650 cells with capacities greater than 3500mAh are absurdly priced for only a 10-15% increase in capacity. Furthermore, Sony conducted extreme tests to extract as much energy as possible from the cells.
To achieve 3,500 mAh, the battery must be discharged at 23°C with a constant current of 0.2 x 3.5 A, or 700 mA. The E8010 battery has 40 cells structured 10s4p; that is, ten blocks of four parallel-connected cells are put in series. The average discharging power for the entire battery is 108W, which translates to 0.7A/cell x 40 cells x 3.6V. I think this is ECO mode territory. BOOST uses the maximum power allowed by the MCU, probably 500–600 W.
Also from table 2 we learn that the battery has a nominal capacity of 40 x 3.5A x 3.6V = 504Wh (this is also written on the E8010 label) and a rated capacity of 40 x 3.4A x 3.6V = 489.6Wh. You get that capacity only if you discharge to 2V, which I'm sure the Shimano BMS does not do. I do not know where it does stop discharging, but I assume that it is around 3V.
After I opened the battery I used my DTL-150 to measure the energy stored in the battery by connecting it directly to the battery, bypassing the BMS. I measured 440.15Wh from full battery (41.8V) down to 28V. I didn't go lower because I was worried that I will either damage the cells or block the BMS. I used a constant current discharge protocol as stated in row 1 of table 2: 4 cells x 0.7A/cell = 2.8A discharge current.
The eTuning app reports that this battery has only 74% remaining capacity. However, the measured 440.15 Wh is 87.33% of the nominal capacity and 89.90% of the rated capacity. If I had discharged the battery down to 2.0 V, as Sony did, I would have extracted several more Wh from the battery. Therefore, it is safe to assume that the actual remaining capacity is ~90%. The actual discharge curve can be observed in the following plot.
This result suggests that Shimano's algorithm for measuring remaining capacity is flawed. But what could cause such a poor algorithm? I only have two batteries: One has 120 cycles and 74% life, and the other has 51 cycles and 81% life. These two points map nicely onto the cycle life performance graph in the VC7 PDF (page 6). This makes me suspect that the actual algorithm is a simple look-up table in which you input the number of cycles and get the remaining capacity regardless of how the battery has been used. The graph also shows that the test was performed at 5A per cell and 2.5V cutoff. The cells will never experience such aggressive usage inside the Shimano battery because the BMS stops discharging at around 3V. Furthermore, the highest current for BOOST mode (500–600 W) is ~3.5 A. Moreover, nobody uses BOOST mode at maximum capacity all the time.
In conclusion, if you don't notice a significant reduction in motor assistance length, don't worry too much about reported remaining capacity. For batteries that show a disconcertingly low remaining capacity but feel almost new, it is reasonable to assume that the actual remaining capacity is at least 10-15% higher.
I hope you find this short essay informative.
I have three 8010 batts, one on extended loan and two in regular use. Approx 7k miles on the bike ( second motor at 5k). All the batts seem to work pretty well. Each capacity seems stable.
l have found the same. After around 4,000 miles (and 130 charge cycles) the app says my battery is at 72% capacity but it will still do just over 30 miles off road on a full charge. When it was new it managed around 35 miles.
"I do not know where it does stop discharging, but I assume that it is around 3V."
I would be surprised if the low voltage cutoff is less that 3.3 volts and even that would be less that stellar for the health of the battery long term.
I added the discharge plot. If the Shimano BMS stops at 3.3 V per cell, only 375 Wh are extracted from the battery. If you continue until 3.0 V/cell, you will discharge almost 420 Wh from the battery. If I knew which messages the battery needed to see on the CAN bus, I could discharge the battery through its BMS and determine the exact cutoff voltage. I could also transform the battery into a huge power bank when it's not being used on the bike.
    Join 43,275
