A List of TQ HPR50 Error Code
| Error Code | Cause | Corrective Measures |
| ERR 401 DRV SW | General software error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 403 DRV COMM | Peripheral communication error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 405 DISP COMM | Walk assist communication error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 407 DRV SW | Drive Unit electronic error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 408 DRV HW | Drive Unit overcurrent error | Restart the system and avoid unintended use. Contact your TQ dealer if the error still occurs |
| ERR 40B DRV SW | General software error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 40C DRV SW | General software error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 40D DRV SW | General software error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 40E DRV SW | General software error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 40F DRV SW | General software error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 415 DRV SW | Configuration error | Contact your TQ dealer. |
| ERR 416 BATT COMM | General software error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 418 DISP COMM | Display initalization error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 41D DRV HW | Drive Unit memory error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 41D DRV SW | Drive Unit memory error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 42B DRV SW | General software error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 42E DRV SW | General software error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 440 DRV HW | Drive Unit electronic error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 445 DRV HW | Drive Unit overcurrent error | Restart the system and avoid unintended use. Contact your TQ dealer if the error still occurs. |
| ERR 451 DRV HOT | Drive Unit over temperature error | Permissible operating temperature exceeded or fall below. Switch off the drive unit to allow it to cool down if necessary. Start the system again. Contact your TQ dealer if the error still occurs. |
| ERR 452 DRV HOT | Drive Unit over temperature error | Permissible operating temperature exceeded or fall below. Switch off the drive unit to allow it to cool down if necessary. Start the system again. Contact your TQ dealer if the error still occurs. |
| ERR 453 DRV SW | Drive Unit initalization error | Restart the system. Contact your TQ dealer if the error still ERR 457 BATT CONN Drive Unit voltage error occurs. |
| ERR 457 BATT CONN | Drive Unit voltage error | Restart the system. Contact your TQ dealer if the error still ERR 457 BATT CONN Drive Unit voltage error occurs. |
| ERR 458 BATT CONN | Drive Unit overvoltage error | Replace the Charger and use only original Charger. Contact your TQ dealer if the error still occurs. |
| ERR 45D BATT GEN | General Battery error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 465 BATT COMM | Battery communication error timeout | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 469 BATT GEN | Critical Battery error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 475 BATT COMM | Battery initalization error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 479 DRV SW | General software error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 47A DRV SW | General software error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 47B DRV SW | General software error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 47D DRV HW | Drive Unit overcurrent error | Restart the system and avoid unintended use. Contact your TQ dealer if the error still occurs. |
| ERR 47F DRV HOT | Drive Unit overtemperature error | Permissible operating temperature exceeded or fall below. Switch off the drive unit to allow it to cool down if necessary. Start the system again. Contact your TQ dealer if the error still occurs. |
| ERR 480 DRV SENS | Drive Unit assist error | Restart the system and avoid unintended use. Contact your TQ dealer if the error still occurs. |
| ERR 481 BATT COMM | Battery communication error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 482 DRV SW | Drive Unit configuration error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 483 DRV SW | Software runtime error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 484 DRV SW | Software runtime error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 485 DRV SW | Software runtime error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 486 DRV SW | Software runtime error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 487 DRV SW | Software runtime error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 488 DRV SW | Software runtime error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 489 DRV SW | Software runtime error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 48A DRV SW | Software runtime error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 48B DRV SW | Software runtime error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 48C DRV SW | Software runtime error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 48D DRV SW | Software runtime error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 48E DRV SW | Software runtime error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 48F DRV SW | Software runtime error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 490 DRV SW | Software runtime error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 491 DRV SW | Software runtime error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 492 DRV SW | Software runtime error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 493 DRV HW | Drive Unit voltage error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 494 DRV HW | Supply voltage problem | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 495 DRV HW | Drive Unit voltage error | Restart the system. Contact your TQ dealer if the error still occurs |
| ERR 496 DRV HW | Drive Unit phase breakage | Restart the system. Contact your TQ dealer if the error still occurs |
| ERR 497 DRV HW | Drive Unit calibration error | Restart the system. Contact your TQ dealer if the error still occurs |
| ERR 4C8 DRV SW | General software error | Restart the system. Contact your TQ dealer if the error still occurs |
| ERR 498 DRV COMM | Peripheral communication error | Restart the system. Contact your TQ dealer if the error still occurs |
| ERR 499 DRV COMM | Peripheral communication error | Restart the system. Contact your TQ dealer if the error still occurs |
| ERR 49A DRV COMM | Peripheral communication error | Restart the system. Contact your TQ dealer if the error still occurs |
| ERR 49B DRV SENS | Cadence-sensor error | Restart the system. Contact your TQ dealer if the error still occurs |
| ERR 49C DRV SENS | Torquesensor error | Restart the system and avoid unintended use. Contact your TQ dealer if the error still occurs. |
| ERR 49D DRV SENS | Torquesensor error | Restart the system and avoid unintended use. Contact your TQ dealer if the error still occurs. |
| ERR 49E DRV SENS | Torquesensor error | Restart the system and avoid unintended use. Contact your TQ dealer if the error still occurs. |
| ERR 49F DRV SENS | Torquesensor error | Restart the system and avoid unintended use. Contact your TQ dealer if the error still occurs. |
| ERR 4A0 DRV COMM | CAN-Bus communication error | Check the charging port for dirt. Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 4A1 DRV COMM | CAN-Bus communication error | Check the charging port for dirt. Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 4A2 DRV COMM | Microcontroller electronics error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 4A3 DRV SW | Cadence-sensor error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 4A4 DRV HW | Cadence-sensor error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 4A5 DRV SW | Torque sensor error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 4A6 BATT COMM | Battery communication error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 4A7 DRV SW | General software error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 4A8 SPD SENS | S Speedsensor error | Check the distance between magnet and Speedsensor or check for tampering. |
| ERR 4A9 DRV SW | General software error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 4AA DRV SW | General software error | Restart the system. Contact your TQ dealer if the error still occurs. |
| WRN 4AB DRV SENS | Cadence-sensor error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 4AD DRV SW | Drive Unit control error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 4AE DRV SW | Cadence-sensor error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 4AF DRV SW | Cadence-sensor error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 4B0 DRV HW | Drive Unit mechanical error | Check if anything is stuck or wedged in the chainring. Contact your TQ dealer if the error still occurs. |
| ERR 4C8 DRV SW | General software error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 4C9 DRV SW | General software error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 4CA DRV SW | General software error | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 4CB DRV SW | General software error | Restart the system. Contact your TQ dealer if the error still occurs. |
| WRN 601 SPD SENS | Speedsensor problem | Check the distance between magnet and Speedsensor. Restart the system. Contact your TQ dealer if the error still occurs. |
| WRN 602 DRV HOT | Drive Unit overtemperature | Permissible operating temperature exceeded. Switch off the drive unit to allow it to cool down. Start the system again. Contact your TQ dealer if the error still occurs. |
| WRN 603 DRV COMM | CAN-Bus communication problem | Check the charging port for dirt. Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 5401 DRV CONN | Communication error between Drive Unit and Display | Restart the system. Contact your TQ dealer if the error still occurs. |
| ERR 5402 DISP BTN | Remote button pressed when switching on | Don’t press the Remote button during start-up. Check whether buttons are stuck due to dirt and clean them if necessary. |
| ERR 5403 DISP BTN | Remote button pressed when switching on | Don’t press the Remote button during start-up. Check whether buttons are stuck due to dirt and clean them if necessary. |
| WRN 5404 DISP BTN | Walk assist user error | Activate walk assist by pressing the UP button (Walk) on the Remote until Walk appears on the Display. Release the button directly and press it again to use the walk assist. Contact your TQ dealer if the error still occurs. |
