If reach is what you are after and that plops you on a K1, even for your height, I wouldn't worry too much about the short TT. That's one of the more initially strange aspects of the Voima geo: longer reach for a given TT length. The secret is setting up the bike for an upright stance. Get 50mm riser handlebar and enough stack and a high excursion dropper to get you get tall on the bike. This does 3 things:
- It puts you in an ideal climbing position from the standpoint of the high seat tube angle and the front-center of the bike. You end up with a mechanical/anatomical advantage for climbing with this geo, yet the reach and wheelbase is long enough somehow keep the bike from losing the front wheel contact, even with a 50mm riser.
- IMO, more upright stance will mean less stooping on the downhills without your ass way toward the back (long chainstay to the rescue here).
- The upright stance leverages the high BB geo, making it work better for your when you maneuver the twisties - using lean vs. turning, and then vertical COG control when things get very technical. Definitely, definitely need a dropper with maximum travel with K1 and your height so you can drop your COG down into the bike for additional dimensions of control.
All this said, is from my experience on a K1 and trying too extrapolate if I was several inches taller. So ultimately, YMMV. If you do get the K1, you might freak out initially with TT/Reach mismatch, as I initially did. It will feel cramped at first, although my first ride was with a meager 20mm riser (i.e I wasn't riding more upright initially). Resist the temptation to move the saddle all they back (also, stay away from short saddles with this bike). Understand that you would be on a different kind of bike (especially the K1 because it has a lower aspect ratio compared to the other sizes) and will take time to understand it. TTYTT, the K2 would probably be the safer bet, but with the K1, you might have a more artful ride on the most nimble version of Voima.
