Thanks mate
Our Bodmin moor mud is the same as yours ,?I found the 2.8 tyres on the Levo demmo I had floated and were very sketchy . Great for crossing soft boggy ground and keeping moving at lower speed but forget cornering or having any fun . Lots of bikes run a smaller rear tyre like 2.5 rear and 2.6 front , supposed to roll easier as well as make back end easier to chuck about , probably be less noticeable on an ebike though . 2.6 seems hard to find currently but plenty of 2.5 aboutYep - I'm asking for the Levo, but those types are for my 'old' 2007 Spec. Enduro which I am about to start using as well - looks like a toy now on those 26" tyres, but I feel I need to do some non-ebike riding as wellAt the moment the enduro has 'New York' spec slicks on - won't go anywhere on those here! lol
Does it also follow that it is ok/better (when seeking grip at the front) to have the larger tyre on the front?
I do get the impression that these big plus 2.8 tyres are floating half the time rather than cutting down to find grip! (which I guess is what you are saying Kernow)
As a matter of interest what tyres are you running on your trek?No pic, but the ride today was crashtacular...
Sloppy Slicks, err, I mean Nobby Nics. They weren't to blame for today's unscheduled dismount though, that was down to pilot error.As a matter of interest what tyres are you running on your trek?
Lol what width are they?Sloppy Slicks, err, I mean Nobby Nics. They weren't to blame for today's unscheduled dismount though, that was down to pilot error.
I’ve installed the Schwalbe ProCore system together with Stans sealant. Transforms the Levo regardless of tyre choice. I first went for Nobby Nic’s 2.6 front with 2.8 rear. I’m about to try Butcher Gripton 2.8 as requested by a dealer friend followed by Scwallbe Magic Mary’s 2.6 soft front with 2.8 medium rear. Let’s see.The ProCore system is totally variable via a clever dual chamber valve. I ride the Levo 2 to 3 times each week hard and fast. Since ownership ( 11 months ) I’ve encountered no pinching tearing burping or punctures. Sorted.
Just bought a set of ratbite tubeless inserts , they have been developed by a local down hill rider . Chatting to him I can see his development and experience makes good sense.
Certainly the price is more sensible at £18 per wheel . I’ll post how they perform when I used them a bit .
ratbite.co.uk.
It’s best described as a foam insert similar to cushcore exept it fills the tyre cavity instead of the rim area , I understand much lower pressures can be used safely .18quid sounds alot more reasonable and well worth a test! Let me know what you think and I might get some for testing, is it a simular idea to procore?
whats your thoughts and advatages of riding bigger tyres on the rear rather the front?
I'm tempted about running a ProCore, if my thinking is correct it will help to reproduce the supergravity style casing on normal tyres like my Butchers? replicate a stiffer sidewall etc?
oh and did you just install the standard 27.5 kit? or did you have to buy a 27.5plus kit if there is even such a thing?
Any updates on this yet?Just bought a set of ratbite tubeless inserts , they have been developed by a local down hill rider . Chatting to him I can see his development and experience makes good sense.
ratbite.co.uk.
How does this make more sense?Unlike other inserts this fills the tyre not the rim void , which to me makes more sense .
I find 2.0 racing Ralph tyres to be best on my enduro bike , latex tubes and 65 psi rear and 75 front . I staiten out the corners and keep it light over the Rocks with lots of bunny hops so traction isn’t an issueHow does this make more sense?
If I have this right your insert is on the outside of the tyre and the inflation chamber is now on the inside?
If so you're effectively losing the tyres air chamber, comfort and compliance, reducing grip and increasing rolling resistance and weight.
This is from basic physics of how a bicycle pneumatic tyre works rather than experience. I don't enjoy riding bikes with low tyre pressures so all these insert systems are pointless for me. *Apropriate tyre casings and pressures never let me down.
*Dual ply for DH 2.5 @ 28/34psi
*Exo for enduro 2.5/2.35 @ 32/38psi
*Single ply for trail centres/natural/XC 2.35/2.35 @ 32/40psi
For me anything lower than these pressures cause the tyres sidewalls to fold/lose rigidity in corners (the only exemption would be in hugely wet/muddy natural conditions with very little hardpack/rock). But I still don't bother running lower pressures or even mud tyres as I kinda enjoy the sketchiness.
I'm a massive tyre geek with loads of experience but haven't posted much on this thread as it's full of recomendations for plus tyres. Which I just don't like the limitations of. And people don't seem to be able to cope with my honesty.
What conditions are you using them in?Currently running Vittoria MOTA 2.5 x 27.5; they measure approx. 2.6 on the 35mm rim. Awesome levels of grip, excellent under hard braking and superb cornering. I was previously running maxxis dhr 2.8's F&R
a 27.5x2.3 Minion SS dual compound exo at at 30psi+ unless you are under 12.5 stone
What do you weigh?
or a 2.4 DHRII or a 2.4 shorty. depending on what your mud is like and how you cope riding in it.
Bear in mind that whatever smaller tyre you do put on the rear. It will have a slightly different (squarer) profile than the front as the Spectral also comes spec'd with a slightly wider rear rim than front. I love a nice square tyre profile as it allows you to lean right over and get the edge working for you. I have no idea how you ride though and riding this way simply won't work so well if you run low pressures unless you run a downhill casing. There simply won't be the sidewall support in an exo.
def try a SS exo then. and you can probably go sub 30psi without ruining the edge rigidity or puncturing.
They're £19.99 at crc just now in dual compound and silkworm protection.
if you don't like it it'll hardly be the end of the world at that price. Be quick though. I ordered one last week and they had 8 in stock.
