EMTBSEAN
849
578
Sheffield
I just bought those too (in silver, for my Reign E+ 1), and the difference is dramatic. First day using them I had terrible cramp in weird muscles of my legs at the end of the day, but since then, glorious! Enjoy šŸ‘
Yep I can relate to that without the short cranks, every so often I get cramp in my thigh muscles, this might turn out to be the shortest upgrade ever, shortest in time Iā€™m talking about, time will tell
EMTBSEAN
849
578
Sheffield
Not strictly for my bike but for me when Iā€™m out on my bike
Arminius
400
612
Rhein-Ruhr Delta, Germany
A pair of Hellerman three pronged grommet spreaders for when I fit my new Kiox display, Iā€™m a bit of a worrier and Iā€™d rather ā€œhave it and not need it than need it and not have itā€ and for the sake of Ā£20 itā€™s not worth worrying about, only downside is that they wonā€™t arrive until between the 6 and 12th of January, oh well itā€™ll give me time to gather the other things I need šŸ˜‰
For fitting or undockingā€¦.šŸ«£
Haveland
200
137
New Brunswick, Canada
Sold my Giant Stance e+
Now only have a 2023 Norco Bigfoot VLT 1 that I love way more than I was expecting. I was planning on buying a Norco Sight VLT, but since I love how the Bigfoot is a full power 900wh monster truck, I might go with something like the Trek EXE.
chamaruco
Inactive Member
Dec 28, 2020
393
328
Arezzo
A new pair of essential pair of pedals. After 5000kms and one service kit, stamp2 developed a painful later play.
retuned to these pedals, ridden three years ago under decathlon brand, but they all are vp-001 rebranded.
a service kit is available too
hope they will last longer than stamps
VWsurfbum
šŸ¤“King of BlingšŸŒ
Jan 11, 2021
1,368
2,021
England
Tracked down a set of Hope Tech 4 V4s. Have been keen to try something different than the MT7s I've been running... finally going to scratch that itch. Should arrive Friday along with new discs and adapters.
Will be interested to hear your comparison.
Mteam
1,789
1,726
gone
bought a cheap shockwiz from wiggle
Will be interested to see if it can improve the performance of my suspension
darwink1
184
567
Ontario, Canada
I put on a 35mm Chromag bza stem with extra spacers under it. Also waiting on a 35mm rise oneup ebar to get a little more rise.
D
What bar clamp are you running? I just got the same bike 2 weeks ago. I swapped the risers around, but the bar still seems low. Plan on a 30-40mm riser bar. But if I can just swap the bar clamp, that may be an option.
8,670
Once you have played with it and discovered that it hasn't made much difference then you may consider renting it out to people on here that you know and trust! :)
RM.SGO
61
57
Danville, CA
Well I still need to bleed them tomorrow and alight the calipers but holy smokesā€¦ what a difference in perceived engineering and quality (some testing is needed to verify). The CNC work is incredible. Thoughtful details everywhere. The SRAM matchmaker design is way more customizable and useful than Maguraā€™s (which really had zero adjustability). If these things work 80% as good as they look I will be a VERY happy camper. My only complaint so far is that the twisted cotter pin they use on the break pad retainer bolt is a bit finicky to reinstall.
53C993ED-1C73-4C31-BFCD-229A5F2CEF39.jpeg 919C20C2-A936-47FC-A29C-D3E88F975A42.jpeg 372855BA-7A79-426C-9ECC-F92C7521C661.jpeg B1886643-A2A4-4327-B985-6209E7EA3302.jpeg 52114AF4-8122-4679-A719-EE48E36DF8EB.jpeg 0B9166A4-B31B-4ACC-AD7F-9F1746C3A4B3.jpeg 594163B6-0966-4E9A-957A-B58968EF0416.jpeg
Lee c
259
202
Uk
View attachment 104887 View attachment 104888 View attachment 104889 View attachment 104890 View attachment 104891 View attachment 104892 View attachment 104893
They look incredible
Sander23
700
433
Belgium
Got this bit adapter for my torque wrench so its easier and cheaper to replace bits
And this effetto mariposa flower power wax hope it does as great as zerofrictioncycling says it is
SwampNut
296
350
Peoria, AZ USA
That suspension kit really should just be provided as a rental. Itā€™s the sort of thing I can see using for a few rides and then never again.
Funny thing on perception and those brakes. To me they look look like the things Iā€™ve made on a friends mill and I have very low machining skill. The MT7s look slick and beautiful to me.
darwink1
184
567
Ontario, Canada
Got a set of sexy 155mm cranks to replace the 160mm xts on the bullit.
Question, should I use the plastic shimano washer/pin dealie to locate and keep them on if they get loose or leave it off? Looks like it would work with these arms just like it does on the shimanos..
Thanks in advance for any advice.
D
KnollyBro
870
2,144
Vancouver
I answered my own question, the shimano spacers don't seem to fit.
Photo dump.
First pic is 155 next to 165, next one is 155 next to 160 xt's.
View attachment 104981 View attachment 104982 View attachment 104983 View attachment 104984 View attachment 104985 View attachment 104986
Too bad your cranks didn't come in pink (maybe gold?) as the silver is messing with your bike's Feng Shui :unsure: How/where did you get a pink coil for your shock ? I have a Fox DHX2 SLS col in fugly orange and would prefer it to be either silver or black.
Arminius
400
612
Got this bit adapter for my torque wrench so its easier and cheaper to replace bits View attachment 104912
Hi, re the bit are you not concerned that it will have negative impact on torque values as it may be weaker / softer material than standard TX nut? šŸ¤”
