Has anyone noticed less range on newer levos than gen 2? On my 21 I could pull 60 miles and 4,500 of climb. I seem to only hit about 45 miles on the new ‘22 one. Perhaps it’s the power curve but I ride mostly in eco st 20%. Both are 700wh alloy
My last ride was 68 miles with 3200 climbing, probably 80/20 trail and turbo modes. I got back to the house with 12% left on the battery. I’m a lighter rider so I’m sure that has a lot to do with it. I get better range than all my riding buddies too, I’m the only one on a Levo though.
68 miles , I'd love that kind of milage 😳
I thought I would too but my body was not happy the next day🤣😂 my wife was on maternity leave for 6 months, she went back to work in July. I hadn’t ridden in a long time since I’m the daycare. I went out for a short ride and before I knew I ended up in Fort William, basically did Glencoe to Fort William leg of the west highland way and back. Plus a few side trails that I found on trail forks that pretty much no longer exist.
what I don't understand is why the ohlins online setup even recommends a 507 lbs spring for the turbo levo 22 for my weight...
It looks like your brakes need aligning. If you use some washers you will use all of the pad on the rotor.
Agreed, that is why I have the proper stack height adapters on order as mentioned. This initial test was just to verify clearance on frame and the 2.3mm thickness rotors in the caliper.
This appears to be the one pictured: Part# S166800021
Thank you. It's actually S206500009 for my Gen 3 Levo. I posted about it on the small parts thread but I'll update the post you quoted in case anyone else runs into the same problem.
i am 91kg with gear öhlins recomand 650lb and its perfect!
i am 91kg with clothing, öhlins recomand 650lb and its perfect! trust it.
That's a lot of flat land riding though.. my last ride that was 3600 was 20 miles and that was with about 5-6 riding on the flat road..
OK. Thanks.
I found a button head screw at the h/w store.. 0.7mm Pitch M4x10mm I think.
is this the part? Cause I can’t see how it would clamp on the hose.. I wonder if the S166800021 would work on gen3 Levo, seems like a better fit
Is it possible to purchase individual cogs for the SRAM XG-1295 12 speed cassette, or do you have to buy the whole cassette?
Going to order a RockShox Super Deluxe Ultimate RC2T to replace the X2 on the 22 Turbo LEVO. I believe it to be part number 00.4118.358.004 . My question is if the MEG NEG air can 11.4118.059.014 should be ordered as well or does the Super Deluxe have better ramp up as stock?
you should order the new model with steel shaft 00.4118.359.045, Levo specific
I don’t know about the 2023 stuff but I had really good luck with the Meg Neg on the older RS stuff. I had the older super deluxe ultimate on my SB130, the Meg Neg made a huge difference. It was my favorite shock before switching over to coil.
Hello Turbo Team,
I noticed that new Tubo Levo expert 2023 colors and specification are released but I did not see any 2023 Pro version (colors and spec). Do you have information about it ? Thank you all.
Thanks. I’m 6’5 and 225 lbs. I did many 5k Ft and 50-60 miles rides on my ‘21 alloy. I seem to be down to 45 on my ‘22. Maybe I’ll swap batteries and see if anything changes.
For anyone thinking of running a 29er on the back this is the clearance.
Tyre spesh cannibal 2.4
Chainstay in low
risky for a British winter could probably get away with it in summer
    Join 43,210
