New to tubeless - advice please
John_A
191
62
Just set up my first tubeless set and although I can't hear any leaks, the tyre has gone flat over a couple of days. Haven't used any sealant yet, is this normal or have I stuffed up?
Spangoolies
122
113
You need to use sealant and once inside, give it a good shake all round to try and coat every bit of surface inside or take it for a good ride straight away. Sealant will seal all the tiny gaps you won’t easily know about
John_A
191
62
Thanks! That's what I assumed, but didn't want to put sealant in if I needed to take the tyre back off. So a bit of leakage over a day or so without sealant seems fine?
8,660
Read this thread and you will learn a lot.
