Profile 1 and 2, have I got it all wrong ?
mak
uk
Loving my m10, I've been on bosch gen 4 for 3 years with no way of altering any form of power output, so an app to alter all parameters of the motor is both a novelty and a welcome useful tool .
My understanding of a profile is a blank page, either profile 1 or profile 2 can be set to be exactly what your preference is. Profile 1 could be set for more power than profile 2 or visa versa.
I don't feel the need to have 2 profiles but its a nice touch, i have just set up my profile one to what feels like an ideal . I have to confess this bike in eco mode ( I have it dialled down) is very strong, trail and turbo also feel more than enough.
Is there more power to be had from profile two or as above are they just blanks to be set as you would prefer ?
It appears to me on profile one it allows me to select 60nm .
It's just 2 available settings that you can set as you wish. The idea is that you can set one for max power and one with less so that you can "work" more depending on how you want to ride
Correct, by default, profile 1 is a lower set of power outputs and assistance levels than profile 2. You can set them up whichever way you wish as you've discovered.
Like you, I tend to ride in Eco and get a great range on Profile 1 for only 360whr. My profile 2 is a bit more beefed up across all three modes, but I still tend to ride in Eco.
I don't have an M10, but I do have the Shimano EP8 motor with the two profiles.
I have set Profile 1 for my everyday requirements and I use Eco & Trail, and Boost occasionally. Profile 2 is set up very conservatively in the event that I am running low on battery and with miles still to go. In effect it's my "get me home" setting.
I don't like the profile-thing, so I've set them up to be identical.
I can only assume that means you've set eco, trail and turbo to Max everything on both profiles. So no matter what mode you select everything is set to maximum. 💯 😉.
I never use eco or boost/turbo.
Trail is assist caracter lv 6, max torque 56Nm and assist start lv 3.
I agree with steve,my Ep8 profile 2 is set up not only to “get me home” but also to “make me work” I set profile 2 with 65nM in turbo ,and 27 nM in eco some times even lower,which means on flatter rides I get a good work out but still get a little help.I tend to ride in eco virtually all the time regardless of which profile I am using.Maybe when I get old and decrepit I will wind them up a bit .But Not yet.
    Join 43,266
