BengtWeil
I was just in the process of replacing the chainring on my Orbea Rise M-Team - It came with the E*Thirteen E*spec 32T chainring and I purchased another one to replace the original.
The OE chainring had reliefs for the chain guide screw heads on each of the 5 "spoke" ribs where the spokes attach to the center circular part on the back side of the chainring.
The new chainring does not have these reliefs. The structural ribs on the 'spokes' run right into to the circular center part. Upon installing this new E*Thirteen e*spec 32T chainring, it appears to fit just fine as no interferance is noticed (at least on my EP8) after installation
Once mounted, look closely at the amount of clearance between the "spoke" structural ribs and the chain guide screw head and you'll notice that the clearance is pretty tight. Picture below is taken from above the chain guide, looking down on the chainring, which has the relief.
If you haven't already noticed, the EP8 spindle has some lateral freeplay -
If you press in on the spindle from the chainring side, it will probably move inward .010" to .020". I believe (but have not confirmed) that this lateral play is part of the EP8 design. The problem is that the chainring clearance to the chain guide screw heads has become too tight and may cause the chainring to rub on the chain guide screw heads. Here's the result with the new replacement version of the E*Thirteen e*spec 32T chainring - you can see where the chainring has been hitting the chain guide screw heads and worn a grove into the chainring.
If you have replaced your OE E*Thirteen chainring with a replacement that does not have the relief in the "spoke" ribs, please check the clearance to the chainring screw heads, both as it sits as well as when you push in on the spindle from the drive side, to check if lateral movement is apparent - good probability that it will cause the chainring "spoke" ribs to hit the chain guide screw heads. Also check the backside of the chainring "spoke" ribs for metal worn away from impact, as shown in the picture above
I have brought this issue to the attention of E*Thirteen, and they are baffled since they have not had any feedback of this problem since they have redesigned the 32T chainring, removing the clearance reliefs. If you see there is a problem with your replacement E*Thirteen e*spec 32T chainring, please reach out to Chris at E*Thirteen, using the following email - [email protected] and let them know of the problem.
I originally replaced the OE chainring around the beginning of 2022 and didn't realize the difference in the way the chainring was made (no-relief/structural ribs) until last week when I was again replacing the chainring and noticed the "notches" worn into the "spoke" structural ribs shown in picture above. I also was not aware of the lateral movement in the spindle, which attributes to the lack of clearance, which was not noticed during installation.
Appreciate any and all feedback if others find the same issue exists - Thanks!
