Trek Fuel EXe
Cell4soul
446
1,254
Mesa, AZ
- X01 AXS derailleur and shifter
- SRAM X01 Eagle Cassette
- XX1 Eagle Chain
- I9 Hydra Hubs
- Nox Farlow; 27.5 rear wheel / 29 front wheel (gonna run it mullet)
- DT Swiss Competition Spokes
- Deity Bladerunner pedals
- Deity Apex 35 stem
- Deity Skywire 35 mm handlebars
- E13 E-spec carbon 160 mm cranks
- Shimano XTR 9120 brakes
- Bike Yoke Revive dropper post, 160 mm
- Fox Float X2 shock
- Fox 36 Performance Elite 160 mm fork
- Specialized Power Arc Pro seat
- SRAM HS2 disc brake rotors - 200 mm
- Bridgestone Kryptotal RE 27.5 (rear tire); Kryptotal FR 29 (front tire)
- Huck Norris tire inserts (rear only)
- Lizard Skin Peatty lock-on grips
- Jagwire braided cables
- PNW Components dropper post lever
- MTX Gold Label ceramic pads
- Trek Range Extender
All parts will be silver, chrome. Spokes as well. The bike is in Dnister Black. This is not a cheap build, but it will still be a little less than the 9.9 XTR factory bike (including the range extender). In my opinion, it will be a much better build. I went “all in” on this one. The bike shop credited me about $1,500 for all of the take-off parts.
Cell4soul
446
1,254
Mesa, AZ
Nice !
Just out of curiosity, what does it weigh in at with that build ?
Large frame with pedals is exactly 42 lbs on the bike shop scale. I was hoping for 40-41 with pedals, but don’t think I’ll notice the 1-2 lb difference. Trek weighs medium size bikes, so I am guessing the weight of this build is very similar to a large XT with pedals. I am happy with the weight given I’m on a 160 mm fork, do not have an integrated bar/stem and I’m running a tire insert on the rear. I am sure I could get the weight down to 40-41 lbs if I removed the tire insert, ran lighter tires and went with the xx1 Eagle cassette; but, I wanted a little burlier build for where I ride.
irie
2,017
1,962
Chichester, W.Sussex, UK
I like how you went about your build. I don’t know why eMTB manufacturers don’t offer a frame only option. You’d think with all the component shortages lately, a frame only option would be a no brainer.
eMtb manufacturers also make profits from components which they bulk buy.
Treksurfer
13
Austria
- XX1 Eagle Chain
- I9 Hydra Hubs
is this the original damper? If yes, please send me the Fox tune ID - thanks!
Cell4soul
446
1,254
Mesa, AZ
Where would I find this? If it is on a sticker on the shock, then I have removed all stickers from the shock.
KevinNY
61
87
NYC
Looks like you are using the e-thirteen chainring that came with the bike. Has that been working ok with the SRAM chain?
Soakinoak
Cherry Hill
- XX1 Eagle Chain
- I9 Hydra Hubs
I would be curious about what hardware you have used to fit the X2 shock at the lower pivot?
Upper one should be the same Trunnion mount using the existing upper bolts and hat style washers, I take?
Can't find much info about the lower pivot tho, beside there is a lower bolt and nut...
Have you used any spacers, fox kits, bushings...?
Any help is appreciated.
Cell4soul
446
1,254
Mesa, AZ
I am not sure. I bought the 9.5 and before I ever touched or looked at the bike, the shop stripped it and built it to my specs. They did all the work so not sure what they did or parts they used.
