Are you sure it was a tear and not just a failure?
On my clockwork bike I am running 27.5 x 2.2" Conti Trail King, with sidewall Protection, with black chilli compound, tubeless. Twice now the tyrewall has failed at the bead. The gap was big enough to get all four fingers through. The 1st tyre went after 442m, 2nd after 402m. Once I looked back on the events, both failures were preceded by a bigger than usual pressure loss from one ride to the next for a week or so. Instead of 0-1 psi, it was more like 3-5. I just put more sealant in. There was no obvious sealant leakage at the point until the total failure.
The key point is that on each tyre, the failure was on the same side and in the same place radially with respect to the Conti logo. That points to a manufacturing defect to me. Conti accepted that and I was refunded without argument on both occasions. I had to send a photo of the area of failure and one of the tread, which was fair enough.
I'm still using Conti TKs, but I bought from a different place to try to ensure I bought from a different production run. Time will tell, but I'm on 394 miles with the 3rd tyre! No pressure loss yet, but oohh err!
Now I've looked up the info to write this and am aware of where that 3rd tyre is, it would make sense to check the tyre bead at that point. Hmm, what a fag!
