EatSleepRideRepeat
Just installed the new Zeb ultimate and taking it for a first ride today. Whats your Settings on this fork? Are Rockshox's Tipps accurate..?
Sadly the links not working. Intriguing tool that. Do you know it’s name? What does it do? Pry apart the space between mounts for shock to fit?
I’ve put a 2023 Zeb Ultimate on mine and the RockShox base settings were a good starting point. I’m 95kg and have two spacers in it and 85psi.View attachment 95284
70kg -> 450lbs, DHX2Question for the Coil crowd... What spring rate are you running? I am mounting an Ohlins TTX22m up.
@ 180lbs RTR, I am thinking 480#.
Thanks. The Ohlins calculator works like a charm.70kg -> 450lbs, DHX2
I am running the same shock and use a 18077-14 548 lbs/in with 1/2 turn of preload. I weigh 190ish with gear. My bike is setup mullet.Question for the Coil crowd... What spring rate are you running? I am mounting an Ohlins TTX22m up.
Thanks for the tip. Cant wait for my full Swedish Squish set-up to show up!I am running the same shock and use a 18077-14 548 lbs/in with 1/2 turn of preload. I weigh 190ish with gear. My bike is setup mullet.
Do you have the three fields? Jump number, duration and distance? Maybe the 137 is the number of jumps you did on the ride although I'm not sure about the .1Anyone know what the units are for the KSL Jump Stats?
I've got my bike set to Imperial units, not Metric.
Last jump was reported at 137.1. I'm pretty sure I'd put myself in hospital if that was measured in feet ;-)
Thanks very much,
John
Thanks for the quick response.Do you have the three fields? Jump number, duration and distance? Maybe the 137 is the number of jumps you did on the ride although I'm not sure about the .1
Just channeling your inner Eddie KidThanks for the quick response.
Yes, I do have the 3 fields.
This is definitely the distance field
J
LOL. Yeah boiJust channeling your inner Eddie Kid![]()
Specialized has a Tutorial on their Website: Record your ridesAnyone know what the units are for the KSL Jump Stats?
Thanks very much,
John
I'm on an S4 with 160 cranks. 170 cranks are too long if you ride rocky terrain and need to pedal through chunk.Advice please on crank lengths for a S5.
A mate is just getting a S5, is 6/2.5 78 kg, long legs, shop has offered 170 or 160. 165 not available through this shop at this time. What have you found to work best? Thanks.
I have decided against taking it to the shop yet.Hi, have you received any feedback from the shop? mine is pretty much the same and looks/sounds normal to me...
Hi there,Specialized has a Tutorial on their Website: Record your rides
Even for the US it says meters there. On another Website I just read that the Speed before takeoff and the time in the Air are being used to calculate the horizontal jump distance. Theres no GPS or so measuring that distance.
So, you just flew down a giant Big Air ramp...?
Or you did a wheelie/manual before and after the jump..? Or it just measured a manual as a jump..
I just set mine up to measure my jumping activities. I can't wait to see if I am as excellent a jumper as you areHi there,
Thanks very much for the heads up, I missed that it said meters.
It's definitely over estimating my ability to jump ;-)
Cheers,
J
I hope so tooI just set mine up to measure my jumping activities. I can't wait to see if I am as excellent a jumper as you are![]()
Does anyone know if there is a Garmin watch out there that can record (that is read) all the data of the KSL like the Garmin Edge 130 can?
Hi, the Fenix 6 or 7 works well with the SL motor, but I think that also other Garmin watches can pair and display Specialized data fields…Does anyone know if there is a Garmin watch out there that can record (that is read) all the data of the KSL like the Garmin Edge 130 can?
My pal who is just building up his S5 asks the question what brakes? Standard are the Code R. Should he upgrade to Code RSC or something else like Hope, “Shaguras”, Magura etc.
Thanks.
Thanks.
I might change first better rotors, because Sram Centerlines are not up to today's standard. Look Galfer or Sram HS2 rotors. When I changed to the quality rotor, I was even able to change the front rotor smaller. Retaining better braking power without the problem of overheating.My pal who is just building up his S5 asks the question what brakes? Standard are the Code R. Should he upgrade to Code RSC or something else like Hope, “Shaguras”, Magura etc.
Thanks.
