Suntour Forks
Owen Duncan
8
Burnley
Hi folks I have
just purchased this Giant E second hand and the lockout on the forks wont work. I have seen the fix on youtube for the blue lever version but min is silver and rather than the allen key arrangement has a small flat screw driver type part that the white gear goes on. I have tighten this part but the lockout still wont work. Is there an easy fix?
Stihldog
Handheld Power Tool
2,937
4,150
Coquitlam, BC
I can’t imagine not using functioning forks on any of my trail bikes. Since youhave an eBike, the benefits of shutting off the forks is small. Learn the setup procedure for your fork and adjust the action based on your typical use. Like @Jackware said …”don’t worry about it”. Unless your relationship with others are being affected of course. 😉.
IMO it helps cleanup the cockpit a bit too. Is there a dropper post on your bike?
Owen Duncan
8
Burnley
Thanks for that, not overly concerned unless it was a quick fix. Yes it did have a dropper post but was too tall for me so have refitted the standard post due to my short legs.
Stihldog
Handheld Power Tool
2,937
4,150
Coquitlam, BC
Ah yes. A dropper can be a nice luxury depending on the type of riding you do. There might be a shorter dropper available out there …but it depends on the price/fit/use. In the end, it really depends on the type of riding you choose. And…Enjoy adding up the miles on your eBike.
