With inflation growing as it is the price is going to be laughable by time it hits the shops in UK and EuropeWe were just yesterday told by our Spec. rep that the launch is again delayed until Autumn...
i heared some news from a whistleblower...
60NM Mahle Engine (similiar to the current one)
480wh internal Battery
180wh Range Extender -> 660wh TTL
150m front & rear
new Geo without Side Arm
later Launch because of part shortage, maybe in September/October (battery and other stuff)
maybe true maybe not.
150m front & rear
Its MahleLets hope it gets the new Fauza 60 instead of Mahle. Fauza got 430 wh internal battery
If so Im putting out buying an Orbeas Rise H15.
The S works looks like it has gizmo thing-a-me-jigs on the forks and shock. Nice step forward if you can afford the price tag that will inevitably come with it.
Its Mahle
sounds fatter.
I don't think 60NM will happenIt will go into full fat territory. Spesh introduced new Creo and it is the same engine SL 1.1., There was roumors that Creo will also be on updated engine but no. So I doubt that we will see new engine in SL 2023.
But Rise has Full power motor tuned down. SL 1.1 is not full power. So don't expect this60 Nm seems to be a must to compete in the same category of Orbea Rise.
The Rise is 60 Nm but maximum power is set to 350 watt, not far from the 300 Watt of the actual SL motor.
So the bike can still consume less energy and stay in the lightweight category even if it has more torque.
I own a Rise and my brother a Kenevo SL and I can say that when the input of the rider is very active with higher cadences and the terrain is not so challenging the difference between the two motors is not so big.
A different story when the gradient is more than 15% and the rider input is more passive…
Here… the new Levo SL maybe!?![]()
I’m glad to hear, 35Nm is enough imoI don't think 60NM will happenIt will go into full fat territory. Spesh introduced new Creo and it is the same engine SL 1.1., There was roumors that Creo will also be on updated engine but no. So I doubt that we will see new engine in SL 2023.
