It's here! 2022 Orbea Rise H15
Congrats. My H15 arrived last night from Jenson. Same color and looks much better in person. I unboxed it last night and will start the set up today.
Any thoughts on downtube protection?
I used Ridewrap full kit on my frame and a Bike Armor Shuttle protector on the Downtube for tailgate protection
Bike arrived at the shop in Oregon today and should be in my hand in NorCal by Monday. I'll be adding some more upgrades shortly after. I'm gonna test a Fox DHX2 216x63 in the rear as well as upping the front travel to 160mm and wrap the frame in a full Ride Wrap kit. I picked up a SRAM X01 Drivetrain since my RF NextR wheelset was only available w/ an XD Driver. I'll use the Current Shimano drivetrain to refresh the XT drivetrain on my Trek Rail.
Finished build :
  • Frame Orbea Rise Hydro 2022 140mm travel 29" Boost 12x148
  • Shock Fox FLOAT X Factory 2-Position Evol LV custom tune 210x55mm
  • Fox DHX2 Factory 216x63mm (~161mm rear travel)
  • Fork Fox 36 Float Factory 160 Grip 3-Position
  • Chainring e*thirteen e*spec Direct Mount 32T Boost
  • Crank e*thirteen Plus Alu 165mm
  • Headset Acros Alloy 1-1/8 - 1-1/2" Integrated
  • Handlebar Race Face NextR Carbon 35 20mm Rise 800mm
  • Stem Race Face Turbine R 35mm 50mm
  • Shifters SRAM X01 Eagle 12sp Single Click Trigger
  • Brakes Shimano XT BR-M8120 4 Piston
  • Rotors Magura MDR-P 220mm Front/203mm Rear w/ speed sensor magnet
  • Cassette SRAM GX Eagle 10-52T 12sp
  • Rear Derailleur SRAM X01 Eagle 12sp
  • Chain SRAM XX1 12sp
  • Wheels Race Face NextR 31 Carbon 29"
  • Tyres Maxxis Dissector 2.60" front
  • Tyres Maxxis Dissector 2.40" Rear
  • Seatpost OC MC20 Mountain Control Dropper, 31,6mm 170mm (210mm Oneup V2 coming soon)
  • SEATPOST LEVER Shimano SL-MT500 I-Spec EV ( coming soon)
  • Saddle Specialized Power Pro Elaston 143
  • Chainguide Orbea Rise chainguide
  • Motor Shimano EP8-RS
  • Battery Orbea RS Internal 540Wh w/ Range Extender (Due in 6 weeks)
  • Pedals CrankBrothers Mallet E
  • Grips Wolftooth Fat Paw
Very Nice! I've got a stock H15 that I've had for a couple weeks now. Question for you, since you've torn into it. My rear thru-axle kept loosening, so I took it out and cleaned the threads. That said, I've noticed that it doesn't thread in as far into the left axle nut as I would expect. On all of my other bikes the thru-axles is flush or protrudes through the opposite side nut. This guy looks 5/16 to 3/8s back in there. Did you happen to notice that on yours?
Same thread about it here: Orbea Rise (H15) rear thru-axle -- 187mm, too short? - EMTB Forums
Orbea lists it as correct at 187mm, although it looks stupidly short to me.
Latest update to my Rise is a 2022 Fox Factory 38 Grip2 160mm fork. I found the RaceFace Next R31's to feel flexy. I thought it was the frame but swapped my SC resereve 30's over from my Rallon and rear end flex was no longer really noticeable.
Interesting, I have reserve 30s and thought their stiffness is what made me bodice the rise back end flex.
Then definitely don't try RF Next R carbons LOL. I've always ran Reserves on all my bikes, tried Nobl TR32's on my Spur which were good. Got are great deal on the RF's cuz I couldn't find Reserves at the time....should have waited.
I have next sl bars on mine!
