Mike640
I wish....Is that you? I can see that you're in Sintra, Portugal? Let's ride soon <3
Not my bike but it looks goodIs anyone running a DVO Topaz? I've ran one in the past and really liked it on an ibis. Not sure if there's much to gain though over the RX tuned float X. I may just hold out and upgrade to an X2 or push 11-6
The Alloy Comp comes with the 700wh batteriy - I get 40-50 km out off my 700wh - Sometimes 50-60 kmHello everyone, I'm about to pull the trigger for an ebike and the alloy Comp is in my top choice. I'm a bit scared about battery. I'm 92 kg. I'm only looking to do between 30-40 km, not more. Where I live there's some vertical climb for about 10 km sometime. Is battery will be enough?
Othe question: can we "still" upgrade the TCU unit to the Mastermind one?
Cheers, I love you guys!
How do you weight? (If it's not too personal)The Alloy Comp comes with the 700wh batteriy - I get 40-50 km out off my 700wh - Sometimes 50-60 km
I have the Mastermind on my S-Works - don't know about upgrading the TCU
86How do you weight? (If it's not too personal)
I have just swapped my dvo suspension on to my gen 3 running the new topaz 2 had it on my 21 levo before for a short stintIs anyone running a DVO Topaz? I've ran one in the past and really liked it on an ibis. Not sure if there's much to gain though over the RX tuned float X. I may just hold out and upgrade to an X2 or push 11-6
Nice bike, this is the new topaz 230x65 on the cascade long shock link....can't wait to ride it.I have just swapped my dvo suspension on to my gen 3 running the new topaz 2 had it on my 21 levo before for a short stint
Hi, what frame size do you ride?Nice bike, this is the new topaz 230x65 on the cascade long shock link....can't wait to ride it.
I have the jade x on my 21 levo wouldn’t say the coil is great for that frame design if your over 80kg I wouldn’t recommendedHello, I really like DVO let me know if it works well. Has anyone tried the new Giade-X?
but did you have them prepare it for the Levo when you bought it? I saw on their site that with € 100 they change the internal melody and do it as for your bike, for your weight and for your indications. Shock absorbers need to be prepared for each frame, they cannot work well from stock for all bikesI have the jade x on my 21 levo wouldn’t say the coil is great for that frame design if your over 80kg I wouldn’t recommended
Yes it was set up for my weight speed and bike dvo nz does this for every bit of suspension they sell. For my weight 87kg I had to run the 575/700 pound progressive spring had correct sag but it was very active I also got shaft wear using the lock out due to side flex in the frame I’m not saying it felt bad but think the topaz feels better. the topaz 2 which felt a lot more linea but had issues with that after four rides sounded like air in oil and sent it back in which then serviced it and sent it back now it’s in my gen 3 which I rode for the first time todaybut did you have them prepare it for the Levo when you bought it? I saw on their site that with € 100 they change the internal melody and do it as for your bike, for your weight and for your indications. Shock absorbers need to be prepared for each frame, they cannot work well from stock for all bikes
S2Hi, what frame size do you ride?
Thank.
great news, my bike is size s2 too, thanks!
Very nice!Nice bike, this is the new topaz 230x65 on the cascade long shock link....can't wait to ride it.
Very nice!Can you please make some detailed photos of the Cascade link?
Thanks!I have removed it as it interferes with the seat stay clevis before full rotation on the alloy. Need to wait for Cascade to update the links to clear the alloy components....However, this thread has a bunch Cascade Link 2022+ Levo Long Shock Kit - EMTB Forums
Is there a way to monitor the percent of charge on a Gen 3 Levo without disconnecting the charger? It looks like you're stuck with the strip of LED lights, which is more granular than I'd like.
When charging there is no connection between battery and TCU / Motor.Just the 4 bars of blinking green lights at the charging port. Each bar represents approximately 25% charge. I did read that your bike TCU should not be powered on when charging, so I don’t think there’s another way to monitor. It would be great to be able to have the mastermind TCU powered on so you could see exact charge percentage during charging.
