I was accused of having derestriced my giant near the 2 year mark because average speed / % battery usage etc didn't add up. I was innocent, and able to pount towards factors in my usage to explain it - eg I regularly towed / pushed my kids up hills +/- a high % of the rest of my usage was in eco or off mode. The dealer argued VERY hard over the phone but successfully advocated for me , but it was a tense phone call ( a warranty motor was at stake)
My instinct is they can suspect derestriction, but it'd be hard to prove.
I guess it depends where your hands are.I have on occasion pushed a mate uphill on his normal bike. Wonder if that sort of use looks suspicious?
on his fanny(pack)I guess it depends where your hands are.
I would imagine its fairly easy to find out if its been derestricted, most systems record speed and distance travelled at all times, so if you ride over the limit a lot its gonna notice!
Not if you only ride uplift days!?![]()
In that circumstance I guess there will very little crank rotation to go with it though so it wouldn't ping up as suspicion.
Thats the thing though, these speedboxes modify the speed signal, so speed (and therefore diatance) looks lower than it really is. So looking at a log of speed and distance it will look normal, but will be using more battery for a given mile than would be considered normal. So I suspect they do look at kW per mile or some similar metric to determine derestriction or not.I would imagine its fairly easy to find out if its been derestricted, most systems record speed and distance travelled at all times, so if you ride over the limit a lot its gonna notice!
not if you are going really fast down hill
it’s agood point to be fair, but do they record that much data? I never give it much thought.
Or go to the bike shop wearing a fat suit, maybe the avg ebiker doesn't need a fat suit?Yeah so you just need to be able to explain an unusual amount of regular load on the bike. Towing kids sounds like a great example, or the fact you always go up mountains but get a lift down![]()
I suspect that most of the main parameters are recorded (speed, crank rotations, battery usage, cadence, torque input, torque output and ride mode). Probably for a set amount of time (last 28 days or whatever).
Something as small as the chip on a SIM card stores driver activities (driving/breaks/sleep/other work/availability) for every minute for the last 28 days on a tacho card so I don't think it would be too tricky.
Down lift daysYeah so you just need to be able to explain an unusual amount of regular load on the bike. Towing kids sounds like a great example, or the fact you always go up mountains but get a lift down![]()
This behaviour combined with my 110kg is I guess what caused raised eyebrows. Once I explained my riding style I got "well I suppose" type responses. Slow acceptance.
For clarity, the data on my giant showed an average speed over 2500 km of 15 kph and energy ysage about twice what would be normally expected - so the distributor decided that meant I was using a badass device ( that only registers every second wheel rotation) .
They ignored a max speed of 75 kph ( that'd be 150 with a badass....I'm not THAT good...) , and even when it was pointed out that over 75% of usage was in off or eco ( tuned down to about 75% assistance) , they still argued. At which point I confessed to towing the kids back up hill ( probably 30% of my use was effectively grinding back uphill with a bike in tow)
Now, I also suspect there was a speed sensor issue , intermittently not detecting wheel rotations so reading even lower speeds . My power was cutting in / out AND , I could sit at 27.5 then suddenly get full torque, jump to about 35 then back under 20.....and I was chewing through running gear a lot quicker than the km reading suggested . So that's another possible explanation if data doesn't align ....
They have publicly stated that the technology is capable of running unrestricted.
Because of your terms of warranty.
#NotRocketScience
