Levo Gen 2 2020 turbo comp hub?
Captain45
Usa
Can anyone confirm what hub they put on the my20 comps? Im bored and thinking about going with a GX Axs and curious what cassette options I have. I've searched a lot and it sounds like it's the shimano HG?
Yes, you have Shimano freehub. You can install PG-1210 or PG-1230 cassette without replacing freehub. I have also upgraded to GX AXS which works perfect.
Perfect thanks. Did you go with a different chain? I have a praxis 36t on the front so I'll def need a new and longer chain
Yes chain must be also 12sp, I have installed X01 Eagle chain shortened to 120 links, original chain was 116 links with 11-42t cassette and 32t chainring. I now still have 32t chainring.
Recently upgraded my Gen 1 Levo to a 2020 Gen 2. My SRAM PG-1130, 11-speed, 11-42t cassette is showing wear and I'm now having moderate ghost shifting I can't micro adjust out with cable barrel adjustment. May also have a slightly bent derailer even after truing the derailer hanger. Thinking about upgrading to 12 speed so I can change to AXS due to thumb arthritis, have been using SRAM grip shifters for years. Know I will need to change free hub to SRAM XD. Can anyone give me a link to the current one to order- there seems to be multiple to choose from? Still have the stock Roval hubs. I'm fairly comfortable doing my own wrenching, have built my last few bikes from frame only(easier to hide the actual true cost from the wife, she does the same thing with her clothes purchases by paying half cash and half credit card).
You don't need to convert to XD as long as you get PG-1230 cassette.
thought I would upgrade to the GX cassette for the 10 tooth higher gear plus I like the idea of a solid pinned cassette vs. stacking individual gears, we do a lot of of back roads which are clay mud and rocks here in the Ozarks so I often pedal out the 11 tooth gear with my32 tooth chainring. With the 10/52 cassette range will also change my chain ring to 34 tooth from the 32 tooth I have now.
