Shimano EP8 Booster testing.
You can remove the booster and tether cable with the strap to use waterbottle.
Trailwatts has been thrown around in enduro’s and extreme jumps for years by customers.
The system will drain both batteries under load sharing values. Your battery display will drop slower as invisible to bike.
As I am only altering the harness with no affect to the bikes electronics there should be no issues when motor/ factory battery need attention.
Sounds good! Lmk when you’re in the US.
Can you explain that more? Thanks!
When you share the load across dual batteries (not bosch system by turning each battery on and off throughout percentage discharge), you are reducing the discharge rate from the factory battery which allows for a steady depletion which in turn provides increased range.
Do they fit onto megawatt ?
If you’d like to get bike to me in the new year and I can add system.
Thank you
Any updates on boasters for the EP8? I’ve got a 2020 heckler MX and would love to find a battery booster solution.
Does it matter what motor it is if you are just adding battery to power the motor, I’m trying to add to my E7000 with a 504 battery and figured I could just splice into the battery power cable with an on/off switch?
    Join 43,241
