Changing display...need assistance.
MOTO13
330
365
Elkhorn, Wi
I bought a 2021 Husqvarna HC7. It has the stock shimano E5000 non-blue tooth display. I want to convert to the SC-E8000 display, but need to know what wiring I will need to do this.
flash
1,050
986
Wamberal, NSW Australia
Spiff
414
240
Earth
If you have an EP8 you need display SC-EP800, it has color and BT. This display and EP8 use the new cables EW-SD300 which are thinner than the old ones EW-SD50, and not compatible.
There are adapters to convert from EW-SD300 to EW-SD50, they are the Shimano EW-AD305
MOTO13
330
365
Elkhorn, Wi
Thanks for the information again guys. I thought it was the sc-e8000 display. Apparently there is an sc-e800 display and I misunderstood this. One less zero. My bad. I called Wheel and Sprocket. Matt is going to install this for me when the new display comes in a week or two. He is pretty much the EMTB guru for them. They are also a Shimano warranty and expert service dealer. I will relay this information to Matt. Thanks again.
Jeremybub
76
47
California
I’ve been looking at doing this upgrade on the HC7, please keep us post on the total cost of the upgraded unit when You have it complete, thanks
MOTO13
330
365
Elkhorn, Wi
I will. The stock display I believe is a e5000. I need the sc-EM800 model to be compatible with the EP8 motor from my understanding. Hopefully this goes smoothly.
eMullet
149
171
Planet Earth
Also Shimano Steps SC-E7000 Display works with EP8 and it's has bluetooth. The Spectral CF7 come with EP8 and that display.
eMullet
149
171
Planet Earth
OK so they are installed by Canyon, nice to know. I replaced with EW-EN100 and that works also it also needs the adapter?
Spiff
414
240
Earth
Yes. It is required to use adapters, if you pull some cable out of the frame you will see a thinner cable and an adapter that connects both cables.
525K
