new battery harness connection decoy yt
Poupy
France
hello I sent my decoy to yt for engine change following repeated e10 errors, they also modified the electrical connection with the battery with this system
Before
After
Who has this system ?
Where did you have to send it and what was the turnaround?
I spoke to yt uk yesterday and they confirmed warranties would be dealt within uk.
I sent the bike to Germany, for the motor and the electrical system it took more than 2 months
That's shite.
Was it before the UK outlet was announced?
What amp is ur charger btw?
I can't see the difference. Are these two pics before(in your hand)/after(installed)? I tried hard to compare, any captn here?
It looks like YT added a small back plate (silver one?) this will shorten the length between the two battery bolts. Also the contact plates for the battery are now surrounded with a guide (?) plate to prevent lateral movement maybe? I will have a check what mine looks like (2019 decoy). BTW never had any error from battery related stuff. Only thing I have is that if I do not tighten the bottom bolt enough first I get a creaking sound when pedaling :)
that's exactly what it
Can this part be sourced anywhere or is it only through their servicing?
Hello,
I got it for free from YT in a couple of days after contacting the customer service about some battery disconnection. It’s easy to swap at home and it worked for me
Hello,
That's good to know thanks.
