you appreciate more the M800 than M500 ?I built the bike especially so that i could go out with my buddies without an e-bike, it just makes up for my lack of fitness so that i can keep up with the boys ?The M800 is very quiet so that you do not disturb anyone in the group.The range with the small 280 Wh battery is around 60 km, and by increasing the voltage to 46.2 volts, the output increases to almost 400 watts
No, in my opinion the M800 has too little power for a mtb, it was not designed for that. I just wanted to show how much weight you can save on an E-MTB. Never make the mistake and ride a minimal-assist bike with a group of normal e-bikes. On the first mountain you will regret it ?you appreciate more the M800 than M500 ?
OK thanksNo, in my opinion the M800 has too little power for a mtb, it was not designed for that. I just wanted to show how much weight you can save on an E-MTB. Never make the mistake and ride a minimal-assist bike with a group of normal e-bikes. On the first mountain you will regret it ?
Somebody had to say it, Beautiful, wait for it, DOG.Light EMTB building with 280 Wh Battery and 17,5 Kg
I've just had a post ride glass of wine .. so the brain is probably not working well ... I don't get it ?? I know .. as @steve_sordy says, if you have to explain it. It's not funny ... can we have a clue ?Somebody had to say it, Beautiful, wait for it, DOG.
You explained it!Crap .. I forgot about the first picture![]()
M800 with 280W battery is probably similar to the Levo SL where you need to do some pedaling. Are you able to pack more battery into the frame? Boost mode should be pretty speedy!No, in my opinion the M800 has too little power for a mtb, it was not designed for that. I just wanted to show how much weight you can save on an E-MTB. Never make the mistake and ride a minimal-assist bike with a group of normal e-bikes. On the first mountain you will regret it ?
Your turning into the Mike Patey of the e-bike worldThe small 280Wh battery is only to save weight, the frame is usually for the M500 / 600 motor and has space for up to 800 Wh. But you have to make the battery cover yourself
View attachment 54298View attachment 54299
Is the 46volts the max you can get?I see the forestal are having 350Wh 51V which implies 14s
Congrats on this nice build, nice color combination, where did get this frame from?The small 280Wh battery is only to save weight, the frame is usually for the M500 / 600 motor and has space for up to 800 Wh. But you have to make the battery cover yourself
Thank´s, the frame is from: Neues Enduro Vollgefedertes Ebike Frameset Kompatibel Für Bafang M500 M600 Motor Motor Lieferanten,Hersteller,FabrikenCongrats on this nice build, nice color combination, where did get this frame from?
Thx
In the highest support level, the M800 delivers just over 400 watts and 55 Nm, a little more than the Mahle in the Levo SLKaroKonig,
M800 is not a straight fit for this frame but only a clever machinist can do it, definitely not for us normal guys here
I'm wondering if you were able to run M800 in similar turbo boost mode of Levo SL?
you could only charge the battery up to 46.5 volts, but that would not be optimal because of the high weight and the higher cut-off voltage of the BMSKaroKonig - luv your innovation! Will you share the custom motor adapter dimension for M800 to fit on the M600 frame housing?
Savas - like your idea of swapping M800/M600 - I want to do the same if possible.
What mod is needed for M800 46v version to run on the same Bafang 48V battery for M600?
Agree! This is perfect for a light 55kg rider. I usually ride less than 2 hrs for 32+km 700+m ele. With a levo SL, I doubled the fun with the same time ?you could only charge the battery up to 46.5 volts, but that would not be optimal because of the high weight and the higher cut-off voltage of the BMS
It's no fun pedaling a 22 kg bike with a weak engine up the mountain?
So it‘s better to built a light Battery for the M 800 to save another 2,5 Kg
I think Karokoenig has the 36v of the motor.There is a second one which is 43v ,which probably would allow more voltage.Probably i will buy later this motor for tests.In europe it is really expensive for what is it.
All Displays who works with the M800 are compatible with the M600/500 too.The display DP C260.CAN is only compatible with M800 ?
Did you fabricate the adapter M800/M500 yourself or is something one could buy?Light EMTB building with 280 Wh Battery and 17,5 Kg
Unfortunately, the adapter is not available to buy, you have to make it yourselfDid you fabricate the adapter M800/M500 yourself or is something one could buy?
regards,
Pelle
