My comment above was a bit tongue in cheek - trying to get the OP to reveal why he thought the bike was so bad.
I've got one, the m team model (hence the user name), owned it for 6 months now, and on the whole its a great bike, it rides really well, plush like a downhill bike, handles nicely, really fast over rough stuff, faster than my 2018 capra by a long way, but no bike is perfect right? so If I was being critical I'd call out the following as negative points:-
1. The geo is quite conservative for a bike in 2021, reach is maybe a touch on the short side for the seat tube length and head angle is maybe a touch on the steep side. I've fitted a superstar components 2 degree slackset which has brought the head angle bang up to date. This is a really minor complaint though really, it does ride really well, and feels more stable than a none ebike of those geo numbers would. And geo is a really personal preference thing, so I feel a bit harsh mentioning this.
2. The orbea dropper seatpost is rubbish, I mean it works and seems reliable, but it gets sticky really quickly in wet weather and needs constant oiling to keep running nicely, this is easy to do though at least. And its quite stiff to push down with your backside. I think I'll be buying a different dropper soon.
3. The rear axle is a bolt thru axle, and the bit it bolts into is a loose kind of nut which sits in a recess in the frame ,but it can just fall out of the frame when you take the rear wheel out. If you're not aware of this it would be really easy to lose this part and end your day before it started. It also a bit fiddly to locate this loose nut back in the correct place once it has fallen out.
4. The battery cover rattles slightly, this can be easily fixed by sticking a bit of sticky backed rubber draft excluder on the inside of the cover at the bottom where it meets the frame.
That's about it ,all just minor annoyances really, I like the bike, I'd be interested to know why the OP thought it was just scrap, maybe he also didnt like the above aspects of it, but I wouldnt say they result in the bike being referred to as scrap.
Always interesting to find out what others like and dislike. I have also purchased an M10 which rivals my S-Works Levo with an Astoria EXT shock and fork. I have had a huge run on ebikes that I bought and sold and kept the ones that I really favor. The day I took out the Orbea for the first time, I put one of my other bikes up for sale. Bikes I have had this last 18 months. 2019 and 2020 Kenevo, 2018 Levo, 2019 Levo S-Works, 2020 Norco sight VLT 27.5, Trek Rail 9.7. Most of these I upgraded heavily to see what I could get from them.
I still have 2020 Kenevo, 2019 S-Works, and the Orbea M-10, so I do have some comparisons that are strictly my opinion obviously.
Here is what I do and dont like about the Orbea
Likes-believe it or not, the Fox Performance 38 and rear shock work nicely together and I am a heavy rider. I can move this bike in the air so well and be confident with the landing.
the Bosch motor has a power delivery like no other and its very quiet. Not the most powerful, but the way it delivers power is smooth and natural. I pretty much just ride in EMTB all day and unless I am climbing tech or descending I hardly have to change power levels or gears.
The fit and finish of the bike is amazing. While I originally wanted the orange, I got the grey and black one and am extremely happy with the appearance. I changed the seat post out the day I got it for an AXS Reverb as I have on all my bikes so I cant rate the OEM post.
What I dont like so much
1. the stupid wheel magnet (which was supposed to be changed for the 2021 FS Wild but mine was not. I got the spoke magnet (yuck)
2. I am not even sure if this is going to be a problem, but the way that the battery cover attaches is extremely small and looks fragile. (I am tempted to put clear tape or frame protection across it to make sure I dont lose it and run over it on the trail.
3. the cover for the power port makes me want to put a sharp stick in my eye. Its awful! Sometimes I get so frustrated with it I am tempted to just leave it off. I will tell you if you also have this problem, put a bit of electrical lube on it and it finally slides in pretty easy
4. Last but not least, as EVERYONE knows except Bosch, the damn power controller is just nasty. I am amazed that they have not got it right after so long and its pretty much public opinion that its awful and we need a more direct and minimal controller.
I think thats about it. I LOVE the FS Wild. Thanks for the idea on make the battery cover to not rattle. I was not sure thats where the rattle was coming from, but I will check that out.
