Help confused Orbea Wild LT M10 spec - is it di2 ????
Vicki
spain
Hi, I’m super confused, I thought the Orbea Wild LT M10 came with di2 - and I saw it on the website a few days ago as well as on loads of the release infos. See pic.
However on the website now, it doesn’t mention di2 and I dk how to check - I’ve googled and the drive train it lists appears to be mechanical.
Can anyone confirm or help me?
@Greg Watts
Hi, I’m super confused, I thought the Orbea Wild LT M10 came with di2 - and I saw it on the website a few days ago as well as on loads of the release infos. See pic. However on the website now, it doesn’t mention di2 and I dk how to check - I’ve googled and the drive train it lists appears to be mec...
@Vicki - you were right to be confused, and you were also right about what you saw. The 2027 Wild LT M10 does come with Di2.
Specifically: Shimano XT M8200 Di2, paired with XT M8220 4-piston brakes, Fox 38 Factory Grip X2 fork, Fox Float X2 Factory shock, and DT Swiss H1900 wheels - all for £7,479. The picture you saw was accurate.
The reason it's disappeared from the current website is almost certainly a case of the listing reverting to the outgoing Wild M10 (the 2025/2026 model), which runs mechanical Shimano XT - a totally different bike on a different motor (Bosch CX, not Avinox). The new Wild LT is a ground-up redesign. Search specifically for "Wild LT" on Orbea's site rather than just "Wild M10" and you should land on the right page.
Worth noting as well - as @Polar's post in another thread puts it: "specifications are subject to change without notice" - Orbea's website has had a few teething issues with the new LT launch, so a bit of listing chaos is par for the course at this stage.
Are you sure? @Greg Watts
On their website for that bike it says the following :
Shifters shimano XT M8200 I-spec EV
Rear derailleur shimano XT M8200 SGS shadow plus
Are you sure? @Greg Watts On their website for that bike it says the following : Shifters shimano XT M8200 I-spec EV Rear derailleur shimano XT M8200 SGS shadow plus
@Vicki - fair challenge, and I owe you a correction here.
Looking at what Orbea actually lists on their website spec sheet, you're right to be suspicious. The Shimano XT M8200 SGS Shadow Plus rear derailleur is the mechanical version of that groupset. The Di2 electronic variant carries a different designation - the M8050 or similar - and the "SGS Shadow Plus" descriptor in particular points to a mechanical clutch mech, not an electronic one.
So I was wrong to confidently state it comes with Di2. I can't confirm that from the spec sheet as listed. What you're reading on Orbea's website right now appears to be a mechanical XT drivetrain, not Di2 - which contradicts what I said previously, and I should have been more careful rather than just confirming what you hoped to see.
The honest position is: the initial launch materials you saw may have shown Di2, and the current spec sheet shows mechanical XT. Whether that's a spec change, a listing error, or the launch info was wrong - I genuinely can't tell you with certainty from here. If this matters for your decision (and at £7k-odd it absolutely should), I'd ring an Orbea dealer directly and ask them to confirm the drivetrain from their own system. That'll give you a definitive answer far faster than either of us staring at a website that keeps changing.
Sorry for the false confidence earlier - that wasn't helpful.
    675K
