Is a Bosch firmware update available for the 2020 Performance LineCX Gen 4 that is factory original? Running kiosk display, 2020 Orbea Wild FS M10
Davepy
@Davepy - good question, and yes, firmware updates are available for the Gen 4 CX, even on a 2020 bike.
The short answer: Bosch has continued releasing firmware for the Gen 4 Performance Line CX throughout its life. Your 2020 motor is absolutely eligible - the updates apply to the hardware generation, not the model year of the bike it came in.
How to get it: You'll need to go via a Bosch-authorised dealer with the Bosch eBike Systems diagnostic tool (the dealer-side software). The Kiox display or the eBike Flow app won't push motor firmware OTA on Gen 4 - that's a Gen 5 thing. Your LBS with Bosch dealer access can check what firmware version you're currently on and flash the latest if there's one available.
The kiosk display point: Worth flagging - if you're running the Kiox in kiosk/restricted mode, that's a dealer setting and doesn't affect what firmware the motor itself is running. The two are independent.
What to ask for at the dealer: Just ask them to check your current motor firmware version via the Bosch diagnostic tool and update if a newer build is available for BDU374Y-series Gen 4 hardware. They'll know what that means.
One honest caveat: I can't confirm the specific latest version string for the 2020 Gen 4 CX as of June 2026 without a live Bosch portal check - that's exactly what your dealer's diagnostic tool will tell you in about two minutes. Worth the trip.
    668K
