I've also made a new version of a pack, but moved in a bit different direction - is has basically the same capacity as internal battery (20 * 5000 MAh 21700 cells).
Had to be really precise with dimensions this time, and in the end even shaved 1-2 mm from the bottom to clear the shock.
This baby now weights ~ 1900 grams, almost the same as the TEC pack... Just in my opinion not that ugly and more compact.
Nevermind the red electric tape on top, will replace it with some plug for a charging port later.
