Muppet stuff is the bestWell using silly internet muppet stuff isn’t really fair.
Seriously though, why are we riding eebs? Is it because they're electric or because they help us up the hills? The latter I suspect.
We can ride a powered bicycle on public roads, limited to 15mph as long as it uses electricity. This thread is slowly proving the product we're all buying doesn't really tick enough boxes, at the moment. So, why can't we have an IC powered, speed limited bike. It would solve all of the issues discussed here. Just puttin it out there.
Yes, I'm sure you could make something cleaner and quieter. But it's not going to be silent, or even noisy motor quiet. If you went 4 stroke it's going to be heavier and more complex. Yes, range would have the potential to be considerably more. Maybe a tiny rotary just for the hell of it?
I absolutely detest all my petrol power tools and will always use the battery version whenever possible .. There are exceptions when it's not realistic I'll admit and sometimes you have to admit defeat :
Over the last 20 years, despite an abundance of tiny IC engines, how many IC MTB's have we seen ? .. It's not impossible, but I don't think it's really what people want ?
Yes I am waiting for cell costs as Samsung are reported to have increased cell prices by up to 50%.Like the Focus Jam2 (Shimano motor) 378wh internal battery, just a shame they made a pigs ear of the TEC battery, I'm hoping @TrailwattsUK will soon be releasing a smaller range extender for the Focus ?
On the subject of light/low power eebs, if you want a giggle, check out the £ of the new Trek e-Caliber. E13k. WTAF?
Wrong. The Bosch Powertube weights 3.5kg. The eBike battery: long range, low weight, easy to chargeThe 625wh battery weighs over 4kg
I'm wondering if, like on some super light ebikes, there is a place in the market for a battery option of say 350wh which would weigh in at somewhere under 2kg?
If we look back to history we kind of had the lighter batteries with less capacity. The battery technology is not ebike dependent so the same rules apply than "anything" else that uses batteries. Would be really really supricing if the ebike's would be the first to implement some really cutting edge battery technology. Aluminium battery articles have been in the internet last 10 years so maybe there's some reasons why don't we have them yet. Is Tesla or Makita using them?I've been reading a bit about the potential for a very high energy density aluminium battery. I understand that finding the right electrolyte and anode material is the problem to be solved but potentially an Al battery could have three times the energy density of an Li battery. Al is also one of the most common elements on Earth and much cheaper than Lithium.
You could offer a trade to someone for changing your 625wh battery to 500wh battery but that would be really bad move. Your requirement is highly independent and 90% buyers would not want a bike that's capacity has been lowered - especially a Trek Powerfly.I didn't start this thread to imply that heavier bikes waste power. It was more to do with the fact that I'm probably toting round two kilos of battery that I don't need. From reading other threads I obviously use my legs a lot more than some so two kilos is really significant. For me weight is also about how the bike responds when you're pushing it round a bit of technical single track.
Tesla seems to be moving more to Lithium Iron Phosphate (LFP) for the moment, mainly due to cost and sustainabiity (easier/cheaper/more ecological) as developments have pretty much equalled them out for the moment. Energy density is almost the same and less reliance on Cobalt.Aluminium battery articles have been in the internet last 10 years so maybe there's some reasons why don't we have them yet. Is Tesla or Makita using them?
Many bikes with the Bosch Gen4 setup are configured like this. Plastic spacer with the 500wh battery, or without with the 630wh battery.Quite a simple solution is multiple batteries in one frame tube, just like a torch. Use some sort dummy spacer to fill up the space when using only one (light weight) cell.
Technically yes but it's kind of really hard to see what could be the use case that I would personally somehow adjust the amount of batteries.Quite a simple solution is multiple batteries in one frame tube, just like a torch. Use some sort dummy spacer to fill up the space when using only one (light weight) cell.
All we need is a motor capable of running on different voltages (batteries in series etc)
This solution keeps weight down when not required and keeps the stylists/marketroids happy.
My Rail 5 came initially with wrong 500wh battery. Got it changed to correct 625wh battery. Only difference that I noticed was the amount of range in Purion.Many bikes with the Bosch Gen4 setup are configured like this. Plastic spacer with the 500wh battery, or without with the 630wh battery.
My assumptation is that: Seems not to be as bike companies are not producing such bikes. They are not so stupid that they would produce bikes that don't sell. Sometimes you have to think that the requirement you propose is ok for a marginal group.is there a place in the market for for a battery option that would save a bit of weight and hopefully a bit of money.
Well for a start if the batteries were 99wH each you could carry a bunch of them in your hand luggage....Technically yes but it's kind of really hard to see what could be the use case that I would personally somehow adjust the amount of batteries.
I recognise that I'm not a pro to adjust my bikes suspension - how could I make the decision on the batteries? Suspension plays (my opionion) much bigger role in overall performance.
That's a great idea. I already have a hand luggage that matches my skirt.Well for a start if the batteries were 99wH each you could carry a bunch of them in your hand luggage....
Gordon
Mean while at Trek HQ: Hold my beer.... e-caliber...
I don't think you can completely discount the option. There are people who are interested and bikes which are starting to fall into the bracket.My assumptation is that: Seems not to be as bike companies are not producing such bikes. They are not so stupid that they would produce bikes that don't sell. Sometimes you have to think that the requirement you propose is ok for a marginal group.
You can/could buy the Trek Rail 5 with 500wh or 625wh battery. I bought and paid for the 625wh version and got the 500wh. Later on changed the batteries in the battery frame and send the 500wh back to shop. Didn't notice any difference.You've still not got mate. The point was about an alternative; an option. So that when you order your bike you could say "I like everything about that bike, could I have the 350Wh version @ £4,400 quid instead of the 625Wh version @ £4.600" for instance. Just like buying an 1100cc car instead of the 1600cc version. Clear?![]()
That ruins the old adage of "They're so ugly, they can't even give them away" - Is seems they can !Focus still do a Shimano EP8 powered bike with small (378wh) internal battery, shame there's only one option though, although it does come with the fugly tec pack as standard now.
