Not sure if joking or not. Seems bigger than Purion and possible waterproof structure raises questions. If Bosch is struggling with it's closed ecosystem in somewhere around 2008 this prototyped screen could be something that Sarah Connor would have used in 1984.
If putting Kiox on top tube and leaving the 3-button controller to handlebar doesn't meet today's strict aesthetic requirements, then you should ride more instead of watching instabikes.
it was a joke!
Its not just about looks for me, its about functonality, or more accurately the fact that the display isnt just a dumb display that the bike can work fine without, half the problem is that if the display fails, or is broken in some way then then the motor also stops working.
So : -
* if you crash and damage it, the motor will stop.
* crash and lose it, the motor will stop etc.
* If the kiox gets damaged in some other way - eg water gets in through the USB port, the motor will stop.
* and its in a very exposed position, so the above is reasonably likely to happen.
Its like bosch havent thought about how to design a robust system. The display should just be a dumb display, its shouldnt be an integral dependent part of the system needed for the motor to work.
My latest issue is that my motor has started throwing a 550 error , when this happens the motor stops supplying an electrical current to the kiox, so the kiox runs on its own battery (so far so good - nice and rubust), but the motor itself still works and I can still get home , but then after a few minutes running on its own battery the kiox then gives a warning that it is not receiving any power and will shut down soon, which it does , leaving you stranded. You can switch it back on and it will run for another few minutes until it repeats the whole silly cycle, until after about 10 or 20 of these cycles whjch is about an hour of run time, the kiox finally runs out of power and wont power up. Why doesnt it just stay switched on until its run out of juice!? why make it auto power off when its not receiving power and hence making the motor shut down.
Its just stupid and badly designed.
