Trail Watts starts testing Range Extender for Bosch.
I’ve halted in this due to restrictions on time.
Hopefully once Bosch updates firmware to be more reliable without glitches as I see currently then I will continue.
Once you've got this sorted I'll be very Interested,for me the only real downside to ebikes is range,I'm constantly checking battery life just incase.ive found the gen4 bosche and 625wh to be better than expected but another 3-400 would possibly stop me even thinking about it..
Sorry but I’m concentrating on shimano as I’ve received my EP8 test bike.
That's disappointing. What made you drop the Bosch testing?
Due to the lack of adjustability like other brands. Bosch battery consumption is not where it needs to be for viability with my module. It can be done and proven but until they move to user friendly apps and software that doesn’t disable the motor with false registering of derestriction. Plus if their 625wh on the gen 4 can’t do 2 laps of my local trail centre vs my 2018 levo on 504wh can?
Over engineered firmware and systems i shy away from. Other brands and motors are well ahead in the user friendly and compliance.
Something wrong there, my 625 easily outlasts all my mates on 504 Levos and is closer to a 700 Levo than the numbers would suggest.
Well same bike, same trail, same rider, same weather and both derestricted. Testing at speed is the only way to calculate range. Anyone could ride huge distances in eco with ultra fitness.
Would deffo be interested. However I have a fox DPX2 shock and it comes very close to the bottle cage on my LT7, I know that with a larger bottle it touches, I will check on dimensions later. What sort or price are we looking at ?
Will this fit with a fox shock in place though?
those dimentions for the bottle battery would fit in my Whyte E150 bottle cage ok. very interested in this product .
I have my finger crossed for the Bosch extender but there is something weird if your 625 Bosch won’t outlast a 500 Spesh.
I’ve had a Levo with the 500 and 700 battery as well as a 625 Bosch and the Bosch is on a par with the 700 Spesh.
I also ride with a 700 levo and a 500 kenevo with one of your 250 extenders and they are all very similar. Same routes, speeds and I’m just slightly the heaviest.
The 625wh Bosch derestricted vs 2018 levo 504wh derestricted and the levo won. Sad to say that the testing I do is very thorough and even after diagnostics and firmware update on the trek rail did not change the results. If you ride in low assist modes and have a restricted bike then you get a better range. Testing on Bosch is continuing after investing in equipment and I receive Bosch booster enquiries daily so my results must be shared by owners to some degree.
i will add to the list for a bosch range extender, i do hope you can sort one.
my 2p on range (generalizing here no actual proper figures) , gen4 625 emtb mode vs a yamamha pwx-2 600 trail mode both derestricted, the Yamaha beats the bosch for range hands down.
im fact just did dalby red 22.5 miles 12deg with a first timer emtb on haibike all mtn 7 Yamaha using mostly turbo/boost beat the other bikes gen4 (moustache 29 trail 10) for battery life. emtb mode can really suck the life out of a battery.
Im also interested in this as it seems a better option than carrying a spare PowerTube. Especially if it is removable for use as and when needed
Hi mate,
I have only just found this sub forum... Nice work!
I find it interesting and practical that you test range with de-restriction. I ride a 2020 Mondraker with Bosch gen 4 and Volspeed 3 and it has been amazing, I just set it at 60kmph and send it (I figured if I'm going that fast it is downhill and I wouldn't be peddling). It has given 1 error in 2 years during a massive down-pour where I found water in the piggyback connectors.
I do a lot of fast commuting miles and find I can get about 40miles in trail mode on one 625wh battery, pedalling as hard as I can.
I have made some small modes to increase range, a lighter wheelset, 2.1 Thunder Burt tyres and a larger chain ring.
I don't have anything else to compare it to but I have been really happy with the Bosch. I would only consider another motor if it was proven to give better range when de-restricted.
I'm happy to test any products if required.
I Will buy this now!!
I have been looking for ages and was just getting ready to buy another battery and a backpack!!
Please PM me if this is available for pre order!!
I'd keep looking as I don't think it's anywhere near to coming to market ..a clue would be if you looked at the dates of the previous posts ..
Once we have finalised module design then we will be able to offer fittings. This kit will not be a plug and play option as Bosch integration requires motor/ battery removal along with selecting cable output and length for each model/ variation.
Here’s an example of a ‘so called’ active system available from one of these companies. Customer’s battery BMS was destroyed and the power input PCB within motor has burnt off the main board and was rattling around in motor casing.
    Join 43,188
