D
Deleted member 7464
Guest
A short post but are the sicom little mudguards really worth £55??
The rear guard is the best on the market. The way it is designed and fit really protects muck and stuff from entry into the motor cavity. Important for pre 2020 models. Look on the forum as well. Lots of discussions on this exact topic.A short post but are the sicom little mudguards really worth £55??
www.centralcoastbikes.com
I have one on already but I'm struggling with the tyre rubbing even after I have shaped it correctly.Cheaper option would be a Central Coast levo guard.
You can also find them on eBay.![]()
Central Coast Bikes - Specialized Turbo Levos E-Bike Mudguard
New rear mudguard for all 2019 and 2020 Specialized Turbo Levos keeps mud, dirt and water out of the junction between the lower linkage and motorwww.centralcoastbikes.com
I agree on the price. I also didn't like that with the V2 SicoMTB guard, there's less protection for the lower swing armSome time back I have asked if someone can post a photo with this Sicomtb rear mudguard after a muddy ride, there was no response...
I do believe mud can be easily thrown over this mudguard (because it is relatively short) onto the chainstay area where protection is most needed ... Not worth the price imho, especially if you account in international shipping ...
Where does it rub? I 've not had an issue with mine.I have one on already but I'm struggling with the tyre rubbing even after I have shaped it correctly.
No.A short post but are the sicom little mudguards really worth £55??
It just to say rubs around the lower arch,I am using 2.6 magic Mary's at the mo so that's maybe not helpingI agree on the price. I also didn't like that with the V2 SicoMTB guard, there's less protection for the lower swing arm
2020 rear mud guard
Another vote for the Central coast guard, great product and great service at a great price.?www.emtbforums.com
That's the one I use already,cracking little bit of kit and does its job well apart from the little bit of tyre rub.Central coast guard ftw. Ordered mine before Christmas and it arrived from the US to the UK in under a week ? Will is really helpful as well, awesome service.
Side note - follow the instructions!!! A few people dont and the bolt holder inside the motor case falls back...
I like the look of the Sico but didnt want to have to remove the Specialized rubber protector.
No.Did you ever pay +€50 for a t-shirt?
Still get mud every where I've been out every other day for 10 days and mud on all clothes., it does keep it out of motor area though.A short post but are the sicom little mudguards really worth £55??
A 2.5 tire doesn't rub. The V2 version gives you the clearance needed but leaves the paint work exposed. I've reinstalled the V1 lower piece without the original plastic protector and find that it gives me the factory clearance and protection of the paint work as well. Here's a photo of the V2 paint exposure problem.It just to say rubs around the lower arch,I am using 2.6 magic Mary's at the mo so that's maybe not helping
I totally agree. Frankly the V2 ( i didn’t have a v1 ) leaves the paintwork more exposed than the factory fit. I wouldn’t buy again for that reason. Creates a problem that didn’t exist ex-factory.A 2.5 tire doesn't rub. The V2 version gives you the clearance needed but leaves the paint work exposed.. Here's a photo of the V2 paint exposure problem.
So I have this, rode once on a sloppy day dirt got in between it and the frame where mounted. Blew it out with a compressor tried to use a small tool to get the gunk out and could not do it to stop rubbing without removing. Is this common?Cheaper option would be a Central Coast levo guard.
I can't say I've had that problem personally.So I have this, rode once on a sloppy day dirt got in between it and the frame where mounted. Blew it out with a compressor tried to use a small tool to get the gunk out and could not do it to stop rubbing without removing. Is this common?
