Well, with all my advice in an earlier post I Decided to update my experience after I had a real outing today.
Fitted Maxxis 29 x 2.5 Assegai DH casing with MAXXGrip compound and Rimpact inserts to my Trek Rail 7.
Standard rims with the Bontrager rim strip in the middle. This is actually a pain, mainly as you can’t get both beads of the tyre into the centre depression, only the one bead at a time. This means getting the 1st bead on is relatively easy, getting the second one on was more of a battle and despite pushing the 2nd bead into the centre as much as possible I still needed leavers to get it on the rim.
But it wasn’t that easy........
I started off with the 1st bead, went on relatively easy, but then put the insert into the tyre and proceeded to try and get the 2nd bead on. Tried for ages, pushed the bead in to the centre as far as ai could but gave up and failed. Took the insert out and eventually got the 2nd bead on but no insert. What I worked out was that in order to get the insert into the tyre and the 2nd bead on the rim I needed to 1st inflate the tyre without the insert and push both beads out onto the rim and pop them into position.
Now with both beads popped onto the rims outer edges I could let the air out and gently just ease the 1 bead off the rim and slide the insert into the tyre. With the other bead still popped out to the edge of the rim it left room for the tyre insert and the 2nd bead to fit into the centre depression (1st time the other bead was taking up this space but now it was popped out to the edge and there was more room). Managed to get the 2nd bead on with leavers and pump the tyre up to 50psi popping both beads out into position.
Now let the air back out, took out the valve core and syringes in the sealant. Magic milk is pretty good, doesn’t dry out and can be topped up if you like. pumped the tyre back up and hey presto, job done.
1st tyre 1.5hrs, 2nd tyre (knowing what to do) 20 mins. Hope this helps someone.
One final observation, When you replace the Bontrager rim strip with tape you run the risk of moving or unpeeling the edge when you use tyre leavers and this can cause leaks. I found that if you can leave the Bontrager strip in place it is more robust and doesn’t get damaged by leavers like sticky rim tape does.
Good luck.
