@avocadough - FWIW, I read somewhere that you can remove the remote from the bars without ill-effects. I think you can remove the TCU from the top tube with a T10 Torx and unplug/remove the remote cable.
However, I just took my first trail ride on my new Levo SL and found it to be REALLY handy. My ride started with a 10 mile singletrack climb (done mostly in Eco mode) and while not super technical, I did find myself flicking it into Trail mode to get me through some really steep switchbacks. Definitely glad that that I didn’t need to reach down to the top tube for the little boost. The remote takes up almost no real estate on the bars and doesn’t interfere with dropper operation, so I’ll be leaving mine on the bars! It’s also useful for turning the motor completely off should you want/need to. I was on a an eMTB-legal trail but still shut off the motor when passing hikers so as not to draw attention to it being an eMTB. In any case, it seems worthwhile to leave it on for a few rides and see how and if you use it. Happy trails!
