Buzz720
Hey, Lets keep this about the Decathlon Stilus.
Hi. I happened to break a bolt on the frame. Decathlon in Sweden did not have spare parts in its range. Does anyone have any idea where to find this bolt?
Woow nice work breaking that! I guess a good hard ware store to try find somthing simular. Would be a shame if decathlon cant order the part for you?Hi. I happened to break a bolt on the frame. Decathlon in Sweden did not have spare parts in its range. Does anyone have any idea where to find this bolt?
Hi did you have any luck with the bolt? Mine just stripped on the shock mount the Alan fixing is oversize on all the bolts so metric Alan keys wobble too much plus mine were far too tight so much my shock was locked, I’ve emailed decathlon uk but probably have no success in a replacement bolt set.Hi. I happened to break a bolt on the frame. Decathlon in Sweden did not have spare parts in its range. Does anyone have any idea where to find this bolt?
I have not been able to get a replacement. I rounded the Allen key but I have temporarily used a torx key instead. I will contact Decathlon Sweden again next week.Hi did you have any luck with the bolt? Mine just stripped on the shock mount the Alan fixing is oversize on all the bolts so metric Alan keys wobble too much plus mine were far too tight so much my shock was locked, I’ve emailed decathlon uk but probably have no success in a replacement bolt set.
So when it comes to batteries I get that storage is best 30-60%. I think it’s also suggested to use it between the same 30-60% range ideally. Some say 80%. I guess this is just to get the most cycles out the pack before it’s dead. What are your guys routines?
Decathlon in Sweden has not managed to find a replacement bolt. They urged me to contact Bosch as according to Decathlon they are the ones who built the bike ... If anyone has any good contacts with Decathlon or Bosch? so I would be grateful if it was possible to find this bolt.I have not been able to get a replacement. I rounded the Allen key but I have temporarily used a torx key instead. I will contact Decathlon Sweden again next week.
Whats the diameter of the shaft and the length?Decathlon in Sweden has not managed to find a replacement bolt. They urged me to contact Bosch as according to Decathlon they are the ones who built the bike ... If anyone has any good contacts with Decathlon or Bosch? so I would be grateful if it was possible to find this bolt.
Is there a date when this happens budProblem solved! Decathlon called me today and announced that all spare parts for the Decathlon Stilus are available to order, they order from Lombardo in Italy.
Just contact the nearest Decathlon to order parts, they need the serial number of the bike. You may be able to contact Lombardo directly yourself, but I know nothing about that.Is there a date when this happens bud
Cheers budJust contact the nearest Decathlon to order parts, they need the serial number of the bike. You may be able to contact Lombardo directly yourself, but I know nothing about that.
I spoke to them in store yesterday and they can’t get any parts ?Problem solved! Decathlon called me today and announced that all spare parts for the Decathlon Stilus are available to order, they order from Lombardo in Italy.
Decathlon should instruct all staff in the correct procedure how to order parts for the bike. And according to Decathlon, the right way is for them to order parts from Lombardo after they have received the serial number on the bike.I spoke to them in store yesterday and they can’t get any parts ?
They didn’t ask for that I tuck it along but he said they was no way of order spares for the bike . I might have to go to another storeDecathlon should instruct all staff in the correct procedure how to order parts for the bike. And according to Decathlon, the right way is for them to order parts from Lombardo after they have received the serial number on the bike.
I need replacement rear bolts as the Alan head stripped because the builders torqued way too tight and I was given a dead end alsoThey didn’t ask for that I tuck it along but he said they was no way of order spares for the bike . I might have to go to another store
Mine didn't ?.Just registered and gave it me ??
WoW when did you get yours budMine didn't ?.
Middle of July, so a bit of a long shot I suppose.WoW when did you get yours bud
Same as me Mine was 15 of JulyMiddle of July, so a bit of a long shot I suppose.
