mtbross
1Up is best rack I've ever owned. Love it. If considering get the Super Heavy for e-bikes. Quality and ease 2nd to none.Need a bike rack, hitch mount, for two emtbs. Any recommendations?
Does US have a different ball?
Or diff square hole there the ball is fitted?
Struggling to find the best option for in Australia, and also wanting it to be 2" hitch mount, not towball. I really liked the yakima one, but apparently it's not rated above 23kg per bike? Which is fine, once the battery is out for my current bike, but what if I got a heavier bike in the future... Or put a friends heavier bike on... I don't want to repurchase..
The Thule T2 Pro XT seems like it may be my only option? It's far from cheap though... The Kuat NV 2.0 may be possible, if they come back in stock. They are very similar in price.
Still have to wait until I get a new car that has the ability to put a towbar, so will see what things are like by then, but I've been trying to keep track on here and save information so I am prepared come the time, or if I happen to see a great sale or something selling second hand!
A potential problem I'm trying to find the solution for. If I'm running a mudhugger front mud guard, will the mudguard get in the way of these wheel clamp style racks like the Holdup or Kuat NV2.0 or Thule T2 Pro XT? I'd prefer to avoid frame mount, and I want to make sure whatever rack I get is a sturdy hitch mount rack that can support the weight of my current emtb (23.9kg with battery, 21kg without), as well as a potentially heavier one in the future.
I'll search for an Australian dealer. thanks!... the Saris I posted above as a better alternative for a bike where you can't get the wheel to clamp directly at the fork crown. I've been using the Saris now for a while and have nothing but great things to say about it. It's designed to clamp the front wheel at a 45 degree angle which will clear any mudguard or fender. It also clamps both wheels and not your frame....
Can you show a picture of it with one Turbo Levo on it ? We were not able to do thatI've got the Easyfold XT 2. Seems good for 2 bikes.
Not really. I only have the Rockrider EST-520 bikes. Would that do?Can you show a picture of it with one Turbo Levo on it ? We were not able to do that
... Saris I posted above as a better alternative for a bike where you can't get the wheel to clamp directly at the fork crown. I've been using the Saris now for a while and have nothing but great things to say about it. It's designed to clamp the front wheel at a 45 degree angle which will clear any mudguard or fender. It also clamps both wheels and not your frame...
I just scored a +2 for my Hold up on Craigslist. I might use it once or twice a year but it is handy to have and won't lose value. While I doubt I will every use it as a 4...I am debating on just cutting the 4th off and making it a 3 bike.
My mistake, I thought it was on the Levo sub-forumNot really. I only have the Rockrider EST-520 bikes. Would that do?
I would just get a replacement, the part is only $66.00If you do cut off the 4th one, I'd suggest fabricating a collar/sleeve that you could use to reattach it when needed. That's what I'd probably do. Obviously there are some safety concerns if it isn't done correctly.
This will do two. Easily.
Sweet - will get the same rack (already have the same bike ;-). Any tips and tricks I should be aware of?
I've noticed this doesn't have any lighting or numberplate mounting - What have you done regarding lighting and numberplate? Do you find lights are unobscured enough? How are you mounting a numberplate?
I really wanted the Kuat, but from what I can see, it wont work around the fenders I have on the bike. They are not overly huge ones, but they will get in the way of the clamp point on the front wheel I believe. And even on other bike, the basic ones on those.... Which is a shame..I actually get compliments about the look of my Kuat NV 2.0.
I was referring to "cutting off the 4th tray". No "replacement part" when you cut metal!!!
I was only after a 2 bike fit one, but I don't think it'll end up doing the trick sadly.
I just pop the front fenders off and toss em in the trunk.Just switch to short View attachment 46347
fenders
