Bosch Gen4 gets more power, is faster than Turbo Levo in drag race
Boschfanboy
9
I could say that these tuning & tweaking limitations have been very well known at the time you have made an agreement to go for Bosch closed E-bike ecosystem.
It's a bit hard to follow what you really need. You need more power, the TOUR is nice but EMTB is not. EMTB is bad because pressure but SPORT is good because pressure. Would it be easier to just not update your bike?
What do you actually need for your 23kg trekking/mountain bike?
* In the case of the Performance Line CX, eMTB mode can replace Sport mode. It can be activated/ deactivated by the bicycle manufacturer and the specialist dealer.
I have updated my bike to the latest 85nm update, but it’s thrown out my SPORT mode, and forced me to use EMTB mode instead, that’s my whole issue, why are BOSCH telling me what mode to use after an update, and if I want to tweak any power settings I am required to buy a 500 pounds computer of theirs and alsothrn pay a further £8.99 in their online shop to do so.
Why can’t we have both SPORT and EMTB mode, why is their a sacrifice?
Cris
30
45
Beds
Here’s a thing.
Something very different in battery management software.
After first full charge since update, the range is indicating way lower in all modes than it did.
ECO down from upper 90’s down to 65.
EMTB down from upper 40’s down to 35
Maybe it is just a more accurate representation, or maybe it is lower?
This may be a concern on my normal riding in ECO and TOUR.
Something to monitor over the next few rides
Mine did the same, but after a couple of rides it’s like it’s “learnt” what power your using and now reads about the same as before. I guess it’s something to do with having it flashed with the new software.
Gazzaaitken
122
144
Word of warning make sure your dealer loads the correct software version, I have been running about today with less power. Sport mode and no emtb only 300% support and 60nm.
Back to the dealers to get the correct version fitted, bugger
PJ27
107
40
Gosford, NSW
Hi everyone,
reading through the thread and feedback the correct Bosch Gen 4 latest upgrade does both the battery software and the motor software and after upgrade the details should read (on Kiox)
Motor Software: 1.1.0.0 (mine currently v 1.0.3.0)
Battery Software: 1.10.0.0 (mine currently v 1.9.1.0)
Is that correct?
Tony.OK
191
234
Napier, New Zealand
Hi everyone,
Is that correct?
Yep correct, just had mine done today and got a printout checklist.
Purion will also display same, power off and press pwr up, down and power on buttons together and display will cycle through firmware numbers.
Bouddha77
14
Switzerland
hello
i have the same check list printed and was wondering what does the min and max transmission ration means ?
mine for max transmission ration says 3.09?
do you also have this value?
rgds
Tony.OK
191
234
Napier, New Zealand
hello
rgds
Mine has 3.40, no idea what it means, maybe the difference between a UK spec and NZ 32kph spec? Wheel circ is saying 2211mm.
MsO
258
168
swindon
Getting my new cube stereo 160. TM today update has been done gonna put speed box 3 straight on bike that's gonna make it fun to ride ?
Tony.OK
191
234
Napier, New Zealand
And mine is 3.04
I think it will be the gear ratios your bike is fitted with.
Probably so that the Bosch software detects any mechanical tampering to defeat the speed restrictor.
If it is, it begs the question, do you need to have it re-calibrated if you change the cassette or chain ring size?
Could well be right, mine is sram 34t with 11t highest giving 3.09, 34t with 10t is 3.40. Maybe the shop just enters gearing and made a mistake of using a 10-50t cassette?
If it was for calibrating it would only matter in highest gear though. My speedo is 2kph low compared to gps which is more likely a wheel circumference error.
Our 32kph limit is perfect for trails anyway so not worried about it ? the motor is good pre update, quick test in street with update it seems like its going to be a weapon of a motor on the Rail ?
Darren66
100
60
uk
hello
rgds
Just had mine updated today, transmission ratio is 3.45 max, 0.9 min.
Bouddha77
14
Switzerland
Yes, I guess this is just the transmission ratio of the cassette to crank as some others wrote.... I was afraid it had something to do with engine torque/power
Sofaboy73
68
34
for those of you that have had the upgrade done, any idea how to consistently get boost feature to work? i thought it was meant to be a quick stamp on the pedal to drive you over techy stuff where you didn't want to risk a pedal strike. works sometimes, but not others?
Jamze
391
720
Oxfordshire
Whilst it will no doubt assist the timing of pedal strokes, I am not sure if that translates into a stamp on the pedal feature that, in itself would reduce the risk of pedal strikes.
If there is one though, hell I could do with finding it...
Extended Boost is described here, 17 mins in.
Fingerpuk
250
197
Kent
I can’t get the update. I’m talking to the shop as they sold it and described it as having the new motor. Bit annoyed.
But also don’t really care that much, as I now use Eco and Trail for almost everything and Turbo for the mental singletrack “let’s try not to crash” sessions.
Fuzz
56
34
Yarrahapinni, NSW, Australia
Hi all, I just got the power upgrade, and the display reads 1.1.0.0, the thing is, I've lost EMTB setting, and it's now SPORT, anyone else had this happen? It's raining here, so I can't road test... previous firmware was 1.0.3.0...I'm confused
Fuzz
56
34
Hi, wondering what your firmware version is, I've just had mine 'updated' to 1.1.0.0., from 1.0.3.0 but now I've lost EMTB and gained SPORT...
Bouddha77
14
Switzerland
Hello
there are several new software versions, I think 6 different versions. They just picked one version I guess I was hesitating with.
there are versions 75 Nm, 85 Nm, with Emtb and without Emtb. When without Emtb, it’s replaced with Sport.
your dealer could have asked you what you want....... imho.
rgds
Fuzz
56
34
Hello
rgds
Thanks for your reply, yeah I'm bummed they didn't ask, it's a 950 km round trip back to see them! grrr
Jimex
16
15
Looking at the bosch firmware website, there is only one listed firmware version for each motor. The latest for the gen 4 is 1.1.0.0. Which I had flashed and emtb option is still there. I would go to a local bike shop and get them to look at it, cheaper than a massive round trip. Then ask your original retailer to reimburse you.
Bouddha77
14
Switzerland
the following video..... in French explains the different versions...
mak
Dec 27, 2019
445
493
uk
Could anyone give me any pointers of a shop to get this download done on my bike around the Notts/derby/Leicester borders. Looking at the bosch dealer web site base is a bit limited and a few shops are not around anymore. Not to fussed about traveling as I will put the bike in the van, more concerned about a shop that knows there stuff (y)
PJ27
107
40
Gosford, NSW
Hi Everyone, I had my 2020 Jam 2 Bosch Gen 4 software updated to 1.1.0.0 correct version I believe. I have notice today on my first ride that in Turbo mode around 14-15kmh (apprx. 9mph) the torque from the motor drops or flatlines, which feels like the motor has cut out but it hasn't. I never felt this on the previous version. I was riding uphill moguls, on the up side could feel the pull then on the downhill side when hitting the 15kmh it would feel like it cut out but the motor wasn't going.
Has anyone else had the same experience? Could the new update for Performance Speed have been loaded as they are the same version 1.1.0.0? Any other ideas?
Fuzz
56
34
When I got my update done, they uploaded the wrong version, it didn't have EMTB mode, and was still 75Nm. Took it back, and there are about 6 versions of 1.1.0.0 The second time I went back, I insisted on watching them tick the right box for update (no facility to print it out). The update is seriously noticeable, heaps more pull at 85Nm. your issue sounds a bit odd...
