Oh ffs.....I've been sweating on it bad, and put stocker back in dropping bloody washers 100 timesSpin the shaft 180 degrees so the knob is at the back.
Could you find out whether they supplied a 60 or 65 stroke ? It would be great to know for certain If the 65 fits and your whether your running It at 170mm or 158mm .Medium frame, yes.
I requested a 230 * 60, but I hadn't noticed the size printed on the shock body. Too excited I guess.![]()
Looks close!, but since the spacer isn't installed, it just made it.Can you check the rebound dial when compressed? Mine is very very close, maybe even touching when I get the proper bottom pin...
Hey man I'm looking at doing this as I already have the ttx 22 on my slash. What's the detail on the trunnion mount? Is it a different shock body? Looks sick!View attachment 34562Ohlins TTX 22 for me! Will work with XL and L frames and mine has mounting hardware for Trunnion frame. ?
There's two types of TTX22M. This type fits the Medium Rail according to TFTuned.;
No, shock is the same. As long as it’s the correct size TF Tuned sell the mounting hardware with Through Bolt to fit to Trunnion frame mounts. Give them a call, they’ll talk you through it!Hey man I'm looking at doing this as I already have the ttx 22 on my slash. What's the detail on the trunnion mount? Is it a different shock body? Looks sick!
Cheers
Out of interest, how heavy kitted up are you for that weight of spring?Finally got correct mounting hardware, fits great on Med frame with Reb adjuster on rear at the bottom. Mine came with the LS spring too.
For those asking about the stroke printed on the Jade they are a standard 65mm but use the bottom spring perch to alter stroke by supplying diff thicknesses for application.
Looking forward to trying it out, yes I fitted to a dirty bike haha, had just got back from ride and parts turned up.....couldn't wait ?
About 95kg.Out of interest, how heavy kitted up are you for that weight of spring?
Have set at about 26% without very much preload needed on spring, I just gave weight and riding type to NZ DVO and they tuned to suit....will test tomorrow and find out if its ok ?How much sag? I'm under 90KG and going for a 550!
Just went and unwound till spring was just loose and its exactly 3 turns, so 550 is prob bang on, think my reb is too fast so might send back for a stiffer tune, will see how it goes tomorrow b4 work and report back. If it needs a 550 it'll def need a slower reb tune anyway.How much preload? Shouldn’t be more than 2-3 turns I think. More than 3 turns means the spring is too soft.
According to the spring rate calculation on TFTuned I need a 539lb spring for 28% sag, and that’s without taking into account the extra weight of an eBike.
Suspension 201: Basic Setup | Blister
Want to maximize performance and comfort on your bike? Here's how.blisterreview.com
