CjP
PRIME TIME
You must have the tiniest legs or are the laziest person if you think that.“Kenevo SL”? That just sounds wrong.
The Kenevo SL will be the perfect bike if it has the current enduro frame with a slightly more powerful SL motor.
35 pounds...impressive indeed. Top shelf wheels too.Some updates:
ENVE M630 wheels(CK ISO hubs) on 2.35 racing ray and Ralph & M7 bars and stemView attachment 36699View attachment 36697View attachment 36700
For me personally good spec changes on the 2021 Expert
Specialized Turbo Levo SL Expert Carbon
Specialized Turbo Levo SL Expert Carbon in Cast Battleship / Blackwww.specializedconceptstore.co.uk
this link doesn't work for me?. Comes up with an empty page on Specialized website. I must see the new spec, as I'm currently thinking of buying an expert. Are there any other links or spec sheets available. Can someone copy n paste?
I would agree with @[B]BAMBAMODA[/B] it was likely posted by mistake and has not been removed to shift the last few MY20 experts before the MY21 launch early next month.
Here are the images which were posted on the facebook post on the SL owners group
I sadly don't have a cut & paste for the website from memory the major changes are as follows
Code RS with 200mm rotors front and rear
Fox 36 Performance Elite
Fox DPX2 Performance Elite
GX / XO1 Drive train
No Carbon rims
I'm looking at the (Cast Battleship / Black) and using the following Evans site as guide for when they will drop in UK
Specialized Bikes, Clothing, Components | Evans Cycles
www.evanscycles.com
I have been waiting patiently for these for weeks ever since buying the wife's carbon comp, the due in stock date at Evans as now been pushed to the 16/08/2020 this started at 03/08/2020 and last time I checked was 09/08/2020 so there must be delays. :-(
I’m torn between this and the wreckoning. They say they’re the same geometry but the evil is so much cooler.
Ordered the enduro this morning. Hopefully get it on my hands on friday evening.
Well by the looks of the videos you have posted on this forum, you don't really need an ebike, do you.![]()
| FRAME | FACT 11m full carbon, 29 Trail Geometry, Integrated down tube battery, enclosed internal cable, dropper post routing, 148mm spacing, fully sealed cartridge bearings, 150mm of travel |
| FORK | Fox Float 36, Performance Elite, Grip2 damper, 150mm, 51mm rake, HSC, LSC, HSR, LSR, Kabolt axle |
| REAR SHOCK | Fox Float DPX2 Performance Elite, 3- position adjustment, 52.5x210mm, Rx Trail Tune |
| FRONT HUB | Roval, sealed cartridge bearings, 15x110mm spacing, 28h |
| REAR HUB | Roval DT Swiss 360, 3-pawl design, SRAM XD driver body, 12mm thru-axle, 148mm spacing, 28h |
| SPOKES | DT Swiss Competition Race |
| RIMS | Roval Traverse 29 Alloy, 30mm inner width, hand-built, 2Bliss Ready |
| INNER TUBES | Standard, Presta valve |
| FRONT TYRE | Butcher, GRID TRAIL casing, GRIPTON® compound, 29x2.3" |
| REAR TYRE | Eliminator, GRID TRAIL casing, GRIPTON® compound, 2Bliss Ready, 29x2.3" |
| CRANKSET | Praxis, forged M30, custom offset |
| CHAINRINGS | SRAM X-Sync Eagle, 94 BCD, 30T |
| SHIFT LEVERS | SRAM X01, trigger, 12-speed |
| REAR DERAILLEUR | Sram X01 Eagle, 12-speed |
| CASSETTE | Sram XG-1275, 12-speed, 10-52t |
| CHAIN | SRAM GX Eagle, 12-speed |
| FRONT BRAKE | SRAM Code RS, 4-piston caliper, hydraulic disc, 200mm |
| REAR BRAKE | SRAM Code RS, 4-piston caliper, hydraulic disc, 200mm |
| HANDLEBARS | Specialized Trail, 7050 alloy, 8-degree backsweep, 6-degree upsweep, 30mm rise, 780mm, 35mm clamp |
| GRIPS | Deity, Knuckleduster, Black |
| STEM | Alloy Trail Stem, 35mm bar bore |
| SADDLE | Bridge Comp, Hollow Cr-mo rails, 155/143mm |
| SEATPOST | X-Fusion Manic, infinite adjustable, two-bolt head, bottom mount cable routing, remote SRL LE lever, 34.9mm, S: 125mm, M/L: 150mm, XL: 170mm |
| SEAT BINDER | Specialized bolt-type, alloy, 38.6mm |
| MOTOR | Specialized SL 1.1, custom lightweight motor |
| UI/REMOTE | Specialized TCU, 10-LED State of charge, 3-LED Ride Mode display, ANT+/Bluetooth® |
| BATTERY | Specialized SL1-320, fully integrated, 320Wh |
| CHARGER | Custom charger, 48V System w/ SL system charger plug |
| WIRING HARNESS | Custom Specialized wiring harness w/ chargeport |
Some much needed upgrades. Which just leaves room for some light weight carbon wheels. Maybe carbon bars and it's done.
Installed the fox 36 performance elite forks so I think I’m done. 36# 1 oz, 16.23 kg. Stock fox 34 rhythm fork weighs 4# 6oz, 1.97 kg.
That is a very very respectable weight sir! I have been busy on light bicycles website designing my future wheels. Quite a few rim and Hub options within 1500 to 1600g. Not sure if I should go light as a feather with recon 30/35 and Straight spoke dt240 exp , or maybe go a little heavier with 33/39 rim and dt350
[/QUOT
Mine actually weighed 1480g for the pair with Shimano micro free hub, 28 spoke front, 32 rear, I9 1/1 hubs.
Spec list for '21 SL expert:
FRAME FACT 11m full carbon, 29 Trail Geometry, Integrated down tube battery, enclosed internal cable, dropper post routing, 148mm spacing, fully sealed cartridge bearings, 150mm of travel FORK Fox Float 36, Performance Elite, Grip2 damper, 150mm, 51mm rake, HSC, LSC, HSR, LSR, Kabolt axle REAR SHOCK Fox Float DPX2 Performance Elite, 3- position adjustment, 52.5x210mm, Rx Trail Tune FRONT HUB Roval, sealed cartridge bearings, 15x110mm spacing, 28h REAR HUB Roval DT Swiss 360, 3-pawl design, SRAM XD driver body, 12mm thru-axle, 148mm spacing, 28h SPOKES DT Swiss Competition Race RIMS Roval Traverse 29 Alloy, 30mm inner width, hand-built, 2Bliss Ready INNER TUBES Standard, Presta valve FRONT TYRE Butcher, GRID TRAIL casing, GRIPTON® compound, 29x2.3" REAR TYRE Eliminator, GRID TRAIL casing, GRIPTON® compound, 2Bliss Ready, 29x2.3" CRANKSET Praxis, forged M30, custom offset CHAINRINGS SRAM X-Sync Eagle, 94 BCD, 30T SHIFT LEVERS SRAM X01, trigger, 12-speed REAR DERAILLEUR Sram X01 Eagle, 12-speed CASSETTE Sram XG-1275, 12-speed, 10-52t CHAIN SRAM GX Eagle, 12-speed FRONT BRAKE SRAM Code RS, 4-piston caliper, hydraulic disc, 200mm REAR BRAKE SRAM Code RS, 4-piston caliper, hydraulic disc, 200mm HANDLEBARS Specialized Trail, 7050 alloy, 8-degree backsweep, 6-degree upsweep, 30mm rise, 780mm, 35mm clamp GRIPS Deity, Knuckleduster, Black STEM Alloy Trail Stem, 35mm bar bore SADDLE Bridge Comp, Hollow Cr-mo rails, 155/143mm SEATPOST X-Fusion Manic, infinite adjustable, two-bolt head, bottom mount cable routing, remote SRL LE lever, 34.9mm, S: 125mm, M/L: 150mm, XL: 170mm SEAT BINDER Specialized bolt-type, alloy, 38.6mm MOTOR Specialized SL 1.1, custom lightweight motor UI/REMOTE Specialized TCU, 10-LED State of charge, 3-LED Ride Mode display, ANT+/Bluetooth® BATTERY Specialized SL1-320, fully integrated, 320Wh CHARGER Custom charger, 48V System w/ SL system charger plug WIRING HARNESS Custom Specialized wiring harness w/ chargeport
hopefully by the end of August.This is not on the Specialized website. When is it supposed to be available??
I’ve got both actually, Enduro feels much bigger. My Enduro Expert is only 1.5kg lighter than my Levo SL CC! To me the enduro feels overly cumbersome compared to the SL, except when you’re going down over technical terrain, then it’s simply amazing.Bad ass dude. Interested to see how the new geo enduro compares to our stumpy geo.
What does your 36 weigh? The 160 fox 38 should be about 400grams heavier than the fox 34 and about 150grams more than 36. Will see for sure late August.
Cant wait to smash some lapsI’ve got both actually, Enduro feels much bigger. My Enduro Expert is only 1.5kg lighter than my Levo SL CC! To me the enduro feels overly cumbersome compared to the SL, except when you’re going down over technical terrain, then it’s simply amazing.
im a bit skeptical about all these claims of a new SL. Is there any further evidence available about this new model?Spec list for '21 SL expert:
i spoke to my dealer this morning and they were completely in the dark. They claimed there was a shipment of 2020's on the that will have a 2021 tag, but no real differences in components.
My light bicycle AM930 (30mm internal width), DT350 hubs arrived at the end of May. They are excellent in terms of quality, ride, weight. I'd order them again.That is a very very respectable weight sir! I have been busy on light bicycles website designing my future wheels. Quite a few rim and Hub options within 1500 to 1600g. Not sure if I should go light as a feather with recon 30/35 and Straight spoke dt240 exp , or maybe go a little heavier with 33/39 rim and dt350
Why would you even consider a 42mm?Getting ready to pull the trigger on a 160mm Fox or Lyric - should I stick with the 51mm offset or consider a 42mm?
Thanks!
I use the 42 also. Perfect for meI use 42 mm , brilliant, no more flop , 44 might be the sweet spot though
What does “no more flop “ mean?I use 42 mm , brilliant, no more flop , 44 might be the sweet spot though
