Thats so low! He's already won!! Actually I think I saw a 14.5KG one already on here.@Rob Hancill - you have competition !![]()
Yes there's an xc build someone's done that I think is sub 14kg, and maybe even less than that.Thats so low! He's already won!! Actually I think I saw a 14.5KG one already on here.
Damn thats low! My plan is to build a burly trail ready bike, no way I can get to that level of weight! I'm interested to see how it rides with the range extender only. I got 60Km on the internal 320Wh battery, so if I can get 20-30KM on the half-sized 160Wh I'll be fine for shorter blast around the hills with it.Yes there's an xc build someone's done that I think is sub 14kg, and maybe even less than that.
Edit: Found it
You mean to tell us you've not had each part sent off and "oil slick" finished ?Oh yeah - I could always lose 133g by taking out the multi tool and holder from the headset... but I kind of like it!
Yeah it’s great.Oh yeah - I could always lose 133g by taking out the multi tool and holder from the headset... but I kind of like it!
Yeah, XL for me.You mean to tell us you've not had each part sent off and "oil slick" finished ?
I think you're on an XL aswell, that must add a few grams ?
Love a bit of slickYeah, XL for me.
Still gathering the Oil Slick parts... slowly but surely ?
I bet those levo SS bikes on the floor are lighter ..
Isn't that missing the point?Has anyone built a burly SL? Something that will handle big hits and enduro type riding?
Not really. a 37lb 170mm /150 SL with better geometry (requires 27.5s) Enduro build is easily do-able.Isn't that missing the point?
TBF any Stock SL can.Has anyone built a burly SL? Something that will handle big hits and enduro type riding?
Burly ish ?? 180/180 was on 27.5 but presently on 29's .Has anyone built a burly SL? Something that will handle big hits and enduro type riding?
I am running a mullet right now ~ 65 deg HTA w/160mm front fork (may up it to 170 soon as it's internally adjustable), 334mm BB height. Weight is higher ~40-41lbs, but I have not ditched the boat anchor cassette or heavy front wheel as of yet. Bike is much more suited for "aggressive riding" now.Not really. a 37lb 170mm /150 SL with better geometry (requires 27.5s) Enduro build is easily do-able.
Unless you're a dirt roadie, This guys 32lb SL is pretty shite TBH
Bike still rides closer to a 30lb mtb vs. a 50lb emtb in terms of handling.
In terms of handling feel... which is subjective, and has to do with weight, cog, setup, suspension platform, geo, etc.Erm... yeah...
I bet you've never said that on date night...Trust me, I know how weight affects handling
Fair enough! I will be careful generalizing numbers in the futureI'm definitely going to be that guy.
I wouldn't want any 50lb+ bike (My ESommet is 47)
I still regularly ride a 30lb 170mm FS Enduro bike.
My kenevo was 53lb in it's last guise.
I've said far worse mid penetrationI bet you've never said that on date night...
Like "ow!, Couldn't you lube ?"I've said far worse mid penetration
