Why do you assume you'll get an error if using a Speedbox 3.0?Hi all.
I have a new bosch 4 gen bike - Mondraker crafty RR. Which chip do you guys recommend for my bike? I have a big discount on Speedbox 3.0, so Im prefering it, but I dont want to get errors. Is Volspeed worth to pay more for it?
I found here some posts talking about it...Why do you assume you'll get an error if using a Speedbox 3.0?
I've had one fitted for over 600 miles, no problem at all.
Hello Aerotec,Just fitted a VOLspeed 3 and like that I can select speed limit each time its activated, display in mph. Biggest plus was no countdown as required at end of Speedbox ride and no delay for motor power wimhcih people say happens with speedbox module. Unless discount is large I'd get a VOLspeed.
Hi there,Hello Aerotec,
Have you experience with speed >+32km/h >+20mph for example 24mph
Thank you very much for sharing your experience with the volspeed 3Hi there,
I cranked it up to a 28mph limit and did a super fun 15 mile trip cruising along with the traffic. No issues. Battery went from 100% to 40% though ?.
Range displayed seems to be affected. With tuning off on an eco ride it was showing 29 mile range. Activated tuning and range alternated between 29 and 55 miles. Then a bit later with tuning on range alternated between 34 and 55 but when I deactivated tuning it showed a range of 27. So take range as unreliable.
Long term I'll run it with a 19.9mph limit as that's more than enough for me most of the time. But a high speed burn sure is fun!
No haven't noted anything like that. Maybe it depends on how much time is above 15.5mph? I'll keep a look out but haven't seen any unusual screen behaviours apart from the range value not being accurate and alternating eg 29/55 miles when ibwas on Eco mode.Thank you very much for sharing your experience with the volspeed 3
I also saw that there is compensation for the missing km/mile when we leave the module on at the end of the ride/trip...
Did you observe anything on the screen during this procedure? (like countdown of speedbox 3)
So I have done about 100 miles this week with the module mostly active at 19.9mph and maybe 20 miles of that at 28mph.
Motor responds as soon as I pedal, no delay. Display has no countdown requirement. I do get range alternating between a likely correct value eg 25 miles and a higher value eg. 55 miles but that's OK.
At the end of a ride I deactivate tuning before powering down.
Really enjoyed the tuninh assist as my natural speed is around 18/19mph.
No errors yet... Fingers crossed I don't get any!
Hi all.
Hi, what did you go with in the end? I fitted a vol speed 3 to my 2021 mondraker e crafty and couldnt get it to work properly. Motor would cut in and out. Sometimes cut out at 12 ish mph and kick in at 17ish. Had to take it off aa riding today and couldnt get it working.. Any update on what you did wHi all.
