Beechung
Hi Guy, I just want to some research about the battery life.im 200lb any on 90% eco mode ride,only doing under 30mi& about 3500-400ft elevation, Is that normal?please share what is your setting?
Thanks man ?35-40 miles in Eco on terrain without large elevation gains (< or = to 3000')
30-35 miles in Trail on terrain without large elevation gains.
On straight high elevation days, basically dh runs pedaling back to top, cuts back battery to 25-30 miles on 4000' + type days, using combination trail/eco. Constant use of Trail mode on steep grades chews through battery fast.
175lbs rider high fitness level
So that mean my battery for miles about right ?try tire down to low eco next time.see can ride over 40mi plus In trails ?My Decoy is new to me, but my longest so far entailed 4000' of rigorous climbing over 25 miles. Battery still registered 22% (per Garmin). I'm 165 lbs and fit but I reckon my bike is heavier than some because I'm running dual coil suspension and cushcore tire inserts. This was primarily Trail mode with some eco thrown in.
Keep in mind that Shimano Steps settings may vary.So that mean my battery for miles about right ?try tire down to low eco next time.see can ride over 40mi plus In trails ?
I did this ride on mostly eco, but some boost and trail near the end, and had over 20% battery remaining.What is your mi for ride ?!
Trying to figure out the best way to get to the trail the fastest, not have to spend a ton of energy climbing.
I have a local trail that is about 8 miles away on flat paved path, once at the trail there are a few 2-3 mile loops with heavy climbing. I would then return back on the 8 mile path.
What would you guys recommend for mode settings?
Agreed. I think it's more about feet/metres climbed rather than miles/kms distance. Your 4k feet of elevation is quite close to my 1400m (actually 4600 feet - but close enough). Also depends upon how techy the climbing trail is. For example, one of our climbing trails is a trail called "No Quarter" and it's very techy and seems to use more battery than going up the old access/gravel road.Seems to me better to think of it in feet climbed rather than miles. Mileage varies for me but I can get right around 4K feet of elevation, plus or minus depending on settings, how much steep tech I try and climb etc
I have all my modes set to high, rarely use boost. I had them set at different levels but honestly didn’t notice much difference in battery so they are all on high and mostly use eco and trail.
with eco in high I can use that on fire road climbs and trail for everything else.. boost sometimes.. or just to get home and burn up battery.
I wish shimano would do more with app.. ideally I would have it all in trail and have the switch set to low medium and high trail.. or maybe low trail, high trail, high boost.. something like that, would be nice to have that option. Also would be nice to be able to change on the fly without phone.
Yeah boost mode will suck battery. Sure is fun tho when I only have an hour or two and want to zoom up a logging road.15km, 800m from full battery to flat today. A lot of boost mode but some eco and trail too
Wow Leftside that's some impressive laps!My battery died this evening just before the final descent. 28km, 1460m vertical/climbing. I'm 80Kg. I ride in trail when doing the climbs and eco when descending. Think I'm going to set the battery to "off" for most descending now.
This evening was a total blast. Completely knackered now.
Eco: high
Trail: medium
Boost: medium
that sounds right.. I’ve never killed a battery on last climb so typically my rides are about 3200-4000 then pedal home or to my truck. Could probably get close to that 4800-5000 foot level.
tech climbs are the so fun on ebikes I tend to search out stuff that wouldn’t be possible on normal bike, think it does suck more battery than fire road grind.. then again most road grinds eco works fine.
That's some impressive laps hehe!I did 31km and 1300m of climbing today on Mt. Seymour and got home with 1 bar left on the battery.
2.45 hours of moving time in Trail and Eco modes.
and who said E-mtb's are for lazy people.. I'm exhausted!
