They’ve put #enduro and #specializedgravity on the post. I wouldn’t think it’d be much use for either of them.
You know how social media works right? ?
Yep, but generally you tag appropriate things!
Thanks, always enjoy your Youtube program, I swapped in the Lefty Ocho and 27.5" wheels, removed the main battery and made it a range extender only and got 14.45kg! XC built is another way to enjoy E-MTB, I believe!Picked up mine (long term loaner) today in Comp Carbon spec.
Out of the crate weight, tubed, no pedals in size XL:
Thank you for your comment. Do you live in Surrey? I also lived in Farnham around 2002, Small world!Really like that build, because I can see why you have gone for the parts you have, rather than just try and make the build as light as possible at the expense of ride ability. Top work
Wow! Do you happen to have the weight of the main battery pack after you removed it?Thanks, always enjoy your Youtube program, I swapped in the Lefty Ocho and 27.5" wheels, removed the main battery and made it a range extender only and got 14.45kg! XC built is another way to enjoy E-MTB, I believe!
I have thought of doing similar for trips (if we ever get back to normal) that require air travel
Great rig. What are these tires exactly?Thanks, always enjoy your Youtube program, I swapped in the Lefty Ocho and 27.5" wheels, removed the main battery and made it a range extender only and got 14.45kg! XC built is another way to enjoy E-MTB, I believe!
The spec. of my bike;Great rig. What are these these exactly?
Nearing the 800 miles mark on mine. free hub loosened twice but hasn’t done it for a few hundred miles. The slight squeak from seal in crank area is quieter and hardly notice it now. Chain etc running sweet too but I do always run two chains and swap around every 200 miles and clean regularly. Still loving every ride.So how much have you been riding with sl? Problems so far?
I had it for 700km, so far only problem had been the sqeek sound wich i fixed.
Isn‘t the bottom bracket too low with 27.5“ in the front and back?
Wouldn‘t it be better to put only 27.5“ on the back wich the high setting and keep 29“ on the front?
typo: "can I just remove the tubes and add Stans"Are the rims and tires that come stock with the Carbon Comp SL suitable for tubeless? In other words, to run tubeless do I have to buy new rims or tires or can I just remove the tubes and Stans?
It's tubeless ready for sure.Are the rims and tires that come stock with the Carbon Comp SL suitable for tubeless? In other words, to run tubeless do I have to buy new rims or tires or can I just remove the tubes and Stans?
Actually the easiest wheelset I have set up tubeless. Even adding cushcore was painless.It's tubeless ready for sure.
The plan was to ride 35 miles today but it got hot too quickly and was able to do just 24 miles. Great ride still despite getting sunburned and headache.
How bad the Guide R stock brakes on Carbon Comp really are?
I cannot read many good things about them and having swapped to XT on my previous bikes I wonder if I should do the same right from the start. That said, my regular trails have no long descents but with all my gear on I’m well in the heavyweight class.
