New 2021 debonair spring upgrade
Still 10ml in each.
Cheers buddy?I’m in no mega rush to do it as ive Been building and spending way too much on a Hardtail build!me and my wife are key workers so still working through lockdow,still sending me crazy though??
Singletrack even have a review of a set of neoprene pedal covers :ROFLMAO:
Wow! so they've finally run out of hipflasks to review and first world political correctness non-issues to be offended by?
If anyone without a tinfoil hat on wants to understand exactly what the new shaft/seal head assembly achieves, how it works and how it will perform in comparison to previous incarnations, Here's an attractive guy in a tight T shirt to run through it all for you. He explains it pretty well.
Anyone can find the complete air shaft in 160 mm in stock in Europe somewhere?
  • Like
Reactions: eia
I am about to order this as forks need a service but I am having trouble finding the seal number for the low friction seals. Or can someone give me the old part number so I don't order that one?
Yup, i'll be doing this, always bugged me that the fork sat really low in its travel! Had mine on order for over a month now, looking forward to getting it installed!
Been running the 21 spring upgrade on a 170 Lyrik for about 100 miles now. Does what it says on the tin with the fork generally sitting higher in its travel :)
Fork still sags 10mm with the bikes weight tho as you would expect.
Mine turned up today,going to wait for the cane creek headset to come first so I might as well do it when the forks are out?
You guys still setting your sag to the fork markings? It’s ok I’ve got 10psi less and it’s still only on 25% sag?
With this upgrade I lowered pressure from 90 to 77 psi to have about the same sag as before the upgrade ...
Cheers buddy I was at 95 before and ended up at 83psi so about the same?it does help if you have the battery in??
Just came back from a ride and the front even though the same sag feels higher like I’ve put a 10mm stem spacers in,I’m guessing if you were to set the sag previously while riding you’d of probably seen 35% just seens to hold its nose up more and noticed more pop of jumps with nearly 15psi less ?
