Ripping g
There willy warmers big feet ————??^^ Are those socks for the wife?![]()
Have you tryed it out yet comfort scale ?
Stickers are from ride decals not metalic and not sure if i like the at min front n back shock £20 the screws are pad retainer pins for hope calipers from tarty bikes ebay is best place for oil slick bolts cheers2 things...
Where did you get the brake caliper screws? AliExpress? I'm in the process of changing all my silver screws to these (and a few black ones!)
Are the Fox stickers actually metallic, and do they have the iridescent / rainbow / oil slick sort of look when you move them? If so - where are they from? I was trying to find some RockShox Lyric ones, but can only find flat coloured ones that look metallic.
It's a massive improvement over the original saddle.Have you tryed it out yet comfort scale ?
Adding gravy to this Dinner plate would probably not improve it.A dinner plate...
Before;View attachment 28955
After;View attachment 28956
I'm going to replace the caliper bolts tomorrow with some that are a. stainless and b. the right bloody length!
You might not even miss the two extra gears because with pedal assist, cadence doesn’t have to be micro-managed on a knife-edge... which may be a crucial factor on a manual bike - but not on an ebike. Your chain might last a little bit longer too because you’re not having to shift past so many cassette cogs with ratios unnecessarily close next to each other.View attachment 29659
Shimano XT 11spd derailleur.
Pillaged my old hardtail 10sp cassette, shifter and chain to replace my sram GX 12sp set up. What an absolute revelation it's been. How good is 10sp on an ebike. Set up is a breeze, no faffing about trying to get shifting spot on like with the Sram, it just works. Good riddance 12sp.
So you were able to make an 11speed derailleur work with a 10speed cassette and trigger?
I have always been interested in the Box 9 speed drivetrains, they have just bought out a new version, they have less gears but still a big range. I have heard various reports about their longevity, but the new one seems a step up in quality.
Box One Prime 9 X-Wide Multi Shift Groupset
@Gary did a review of it a while back, but I think he had longevity problems with it
Gary do you have the model number of that zee mech? The only one I see is the m640 and that’s saying a 28t is the largest sprocket.Box two cassette durability life was shocking. smaller sprockets wore out super quickly.
The rear mech also wasn't durable
and the shifters are really cheap feeling in comparison to basic Shimano.
Sunrace make it to Box Components specification
I'd avoid and recommend 10 speed shimano Deore over it every time.
its 11-42 cassette should have enough range for an Emtb.
(I run 36x 11-36 10 speed Zee but have no major health/fitness issues or disabilities though)
I ended up adding in a set of Ergon GA2 grips in nightrider blue and some reasonably color matched Spank Spoon pedals into the order. Unfortunately the DebonAir kit is not in stock so might be a little longer wait for that upgrade...still have at least few more weeks in lockdown anyway!35mm Nukeproof Horizon stem, 2021 Debonair upgrade kit and SKF Seals for my Revelation.
I've ordered some new Crank brothers Stamp 7 pedals. Had the bike over a week now and still have the plastic pedals it came with, also ordered some spares for the bag, chain links, rear hanger, CB M19 tool and a digital pressure gauge![]()
