Levo SL Gen 1 Official Levo SL Thread
Anyone having any problems connecting to their SL, mine won't connect at all, app won't even look for a new bike!
Here is the noise. I guess sooner or later this will come to every SL.
Thanks for the comparison, but these are 2 different bikes, e.g. coil shock (I even owned Capra LTD:) ).
In SL Comp vs SL Comp Carbon theoretically only frame differs and I don't believe it does 1,4kg increase.
As I say, it doesn’t. My figures are quotes of actual weights done by forum members. I actually quite like the idea of building an alu one myself but the 800g cost is a little high for me.
The exercise for the reader, that you haven’t done yet ?, shows there’s roughly around 3-400g between the two materials when YT do a build of the same bike in alu or Carbon.
Here is the noise.
It's not just part of the clutch mechanism or even play in the gears ?
On the bright side, if you leave that bit off the bike you'll get rid of the noise and save a tonne of weight, you'll also be able to ditch the battery, mode selector and TCU.
Badge it up as the "Levo SLow"
It really sounds like space between the gears...could become a constant problem with all Mahle motors...
Do you notice it when "in motion" ?
Not the same motor, but on my 1.3 Kenevo, it makes a horrible "mechanical ripping itself apart sound" when you come off the power (stop pedalling) and you're above the assist limit (25kph) ie going hard on the flat and ease off or going downhill and pedalling for extra speed and ease of for rocks/terrain/turns. If you lower the assist limit to 20kph it almost feels like you have it all the time. I've upped my assist limit temporarily to 45kph and it's pretty much stopped it, as with things as they are I don't want the motor tearing itself apart. (I suspect you can't hear it above 45kph because of higher ambient sounds/oap deafness). It could be it's not a problem and it's just the mechanism/belt accelerating up as it's been temporarily electro/mechanically disconnected above 25kph (guessing).
I wonder if the Bosch gen 4 rattle isn't something similar which is only present at 0 speed and above the cut off ? Some people don't notice it .. or they don't notice it on their first ride, but on subsequent rides - when possibly going faster, they notice it.
Which makes me wonder if the Mahle doesn't also have something similar ?? A good excuse to test it whilst going quickly ?? :-) Roadies probably wouldn't notice it as the terrain is, hopefully, smoother.
Which makes me wonder if the Mahle doesn't also have something similar ?? A good excuse to test it whilst going quickly ?? :) Roadies probably wouldn't notice it as the terrain is, hopefully, smoother.
I only noticed it while "handling" the bike so far, not during riding. I believe while you are pedaling the motor "works" so there is no "space" between the gears. But for example i do hear the sound when walking down over stairs letting the bike roll beside me. Kling, kling, kling, kling, like this.....
Specialized have just created a musical instrument. If we all remove our motors and get together on line with the Bosch guys we could create a brand new sound that could pull people together in this lock down period. With the Spesh Klings and the Bosch Klunks we could be on to something here and bust some serious tunes folks ;)
I would love to play HIM with my Mahle.
The less talented of us can bring our bike frames along, most of us have two triangles ...
In terms of names, I think we should immediately rule out the "KKK" the Kling Klunk Klangers.
Has anyone, before any lockdowns, done a significant amount of riding in the wet/mud yet? Any mud ingress into the covers?
Has it been washed a lot?
I believe Rob said he was pressure washing his SL after some rides.
I have high hopes as for how “UK proof“ the new Mahle setup is. I wonder, is the TCU different to the Levo FF, anyone had a look? @73Steff you’ve disassembled yours, does it look more weatherproof?
Etoni...how do you like the 160mm travel fork and does it make the bike lift on steep climbs?
Also really curious about the rear shock size and how it feels and handles? What position is your flip chip in?
no lift, a super nice ride feeling very badass feeling with the ttx22 coil, flip chip low. just a other bike!
    Join 43,174
